Question about GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
Want to access condensor coils to perform annual cleaning. GE does not indicate where the coils are or how to access. GE FCM 15PU WW
Posted by lslatj01 on
John Hall
    President:
  • 1,218 Answers
Good day,
You can't. They are bonded to the inner walls of the machine and totally inaccessible. Normal for most freezers.
Posted on Jun 20, 2010
Frigidaire upright commercial freezer started a LOUD buzz and the second light was on at the bottom front..turned off..then back on one hour later,.still loud buzz,..any idea what s wrong ?
The green light should be a normal running light and the other one, either yellow or red(ish) should be a high temp alarm. Check the contents to make sure they are still reasonablly frozen and if not start finding the cause....Is the condensor fan motor running correctly? Is the condensor coil clean and free from dirt/lint/fuzz which serves to restrict the transfer of heat? Is there an excessive accumulation of ice build up indicating possibly a problem with the automatic defrost cycle?
Apr 03, 2015 | Frigidaire Freezers
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
My GE upright frost free freezer is not cold enough to freeze food anymore.....its cold but not freezer cold....stuff is defrosting....what could be wrong. I hear it running, but I dont hear it go off...
without getting all technical, look for the condenser coil and be sure it is clean. Some are under the refrigerator and can be accessed by removing a "kick plate." Some are under and in the back and can be accessed by removing a cover with a few screws. Some units have a small fan that moves air over the condenser coil. Look for it and see if it is running. And then there are some that have coils that run up the rear of the unit and when it is pushed back against the wall, the air can not circulate and can cause this issue. This is the simple first step to do before getting a service tech involved.
Dec 16, 2017 | GE 20.3 cu. ft. / 575 liter Upright...
My freezer is blowing but not cold enough to keep it frozen
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Test the compressor motor.
Hope this help in solving the problem. take care....
Sep 15, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
High temp 20-29 F Frequent high temp alarms
check condensor fan if it has one. if not unit may have sprung a leak some where
Apr 10, 2010 | Freezers
Runs but won't get cold
The first step would be to clean the condensor coils to remove the dirt accumulation which decreases their efficiency. Also, check to make sure the condensor fan is operating properly. This pulls room air over the condensor coils and cools the refrigerant.
Oct 09, 2009 | Kenmore Freezers
Frosting up around condensor etc , and the warning light on.
Are you frosting up at the condensor or did you mean the evaporator? If its the condensor then make sure the coils are clean. Still then you will need a tech to look at the seale system. If its the evaporator and the heater is ok then it could be the timer or the terminator on the compressor. Most of the time its the timer.
Sep 14, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Jul 26, 2009 | GE Freezers
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
250 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a GE Freezer Expert? Answer questions, earn points and help others
