Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
Posted on Jun 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv will not turn on red standby light blinks 6 times
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 23, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1523
Points
Tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 310 Answers
  • Posted on Jun 19, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
310
Questions
0
Helped
70697
Points
902
Maybe theres a defect in power supply .if posible just ask it to the qualified Sony technician to repair your tv
2 Related Answers
Anonymous
  • 140 Answers
  • Posted on Aug 26, 2007
SOURCE: 55 in Sony KDF55WF655 Goes to standby and red light blinks 4 times
Check the thermal sensor fuse part# 1-910-023-93 or possibly one of the four fans. If the unit goes into Fan/Thermal Protect shutdown (4 blinks) it can be difficult to determine the cause since the unit turns off too quickly to troubleshoot. Solution: Ground the data line by inserting a jumper between pins 3 and 6 of CN44 on the H4 board. This overrides the protection circuits for troubleshooting. Do this right after turning the unit on and as soon as the lamp is seen lighting. Check pins 2, 5, 8, and 11 of CN6000 on the G2 board for less than 1VDC. Any voltage higher than that indicates a faulty fan. If all voltages are within specs, the H4 board must be replaced. If a fan is found defective, the optical block will need to be replaced if it is located inside the assembly. H4 Board Part Number: A1054674A Replace the following part based on which pin of CN6000 is out of specs: Pin 2: Fan 1 (part of optical block) Pin 5: Fan 2 178723211 Pin 8: Fan 3 178706511 Pin 11: Fan 4 178708111 Optical block Part Number: A1084662A
Anonymous
  • 4402 Answers
  • Posted on Dec 20, 2007
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
MY SONY TV MODEL # KF42-WE610 IS SOUND IS COMING ON BUT NO PICTURE
If you turn it on and the, Power/Standby green light blinks slow 6 times; then it becomes a red fast blink 6 times, pause, then continues to blink red fast 6 times, again and again. this means when it's blinking 6 times is indication of electrical circuitry malfunction. The Television will need service.
I'm assuming that it is an error code. The red
colour wheel issues and defective lamp replacing lamp and light engine color wheel cos its worn out
2helpful
Sony KLV-46S200A LCD TV doesn't turn on, it remains blank with the red standby lighthouse blinking 4 times.
According to the service manual page 6. four flashes is "Backlight Trouble" so if its the light it self or Backlight Inverter Board i cannot tell you.
Service manual can be downloadet here.
http://elektrotanya.com/sony_klv-26s200a_klv-32s200a_klv-40s200a_klv-46s200a_chassis_wax2.pdf/download.html
1helpful
2answers
No tv red blinking lights
Blinking of standby light are fault indications. How many times the standby light blinks at a time. Count it, and inform me.
6helpful
2answers
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
2answers
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
1helpful
2answers
Standby light blinks for 6 times
Did you get this solved yet? Six blinks usuall meand thermal fuse. I can look it up if you still need help.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
