Check your dryer duct hose and vent.....it might be clogged,.....in some cases the duct fills with water and causes dry time to take longer.....on other cases the vent might be clogged and the heat sensor detects that it is hot enough and shuts down the heater element.................
make sure all vents are unclogged.............
dryer duct hose is in the back of the dryer and is connected usually with a duct clamp or tie strap.........disconnect and if i were you replace with a new one.... do not rinse out and put back....it will cause a build up of lint around the inside of duct hose.....the water acts like a glue trying to collect all the lint it could...and eventually it will clog the hose..............just replace with a new one......check the vent were the hot air discharges out of usually outside or rooftop........most vents are covered with a screen or a plastic/sheetmetal flap.....make sure the flap can move.also make sure that it is uclogged and has good airflow...........................
good luck if anything just message
a feed back would be good if this helps...
