The AL4 error on an IMESA washing machine typically indicates a problem with the water supply. Here are some steps you can take to try to clear the error:
Check the water supply: Make sure that the water supply to the washing machine is turned on and that there is sufficient water pressure. If the water supply is turned off or there is low water pressure, this can trigger the AL4 error.
Check the inlet valve: The inlet valve is responsible for regulating the water flow into the washing machine. If the valve is clogged or not functioning properly, it can cause the AL4 error. Check the valve to make sure that it is clean and that it opens and closes properly.
Check the water filter: The water filter is designed to catch debris and prevent it from entering the washing machine. If the filter is clogged, it can reduce the water flow and trigger the AL4 error. Check the filter to make sure that it is clean and free of debris.
Reset the machine: If none of the above steps work, try resetting the machine. Turn off the washing machine and unplug it from the power source for a few minutes. Then plug it back in and turn it on. This may clear the error and allow the machine to function properly.
When the motor is switched on, it must reach a speed of 1300 rpm within 10 seconds; if this doesn't occur, A7 alarm condition is generated.
Possible causes:
Motor winding short-circuited, motor winding interrupted, motor jammed, electrical connections broken or false contacts, tachometric sensor broken or short-circuited.
This control procedure is in operation only during the cold wash and heating phases.
Once the pressure switch has closed in the "full" position, it must remain "full" until the subsequent drain phase; if the pressure switch signals "empty", the fill solenoid is activated for a period equivalent to the period of aperture of the pressure switch.
The maximum aperture time for the pressure switch (T) during the entire phase is 60 seconds; if this period is exceeded, an alarm condition is generated.
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
