If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Change input device to some other like a DVD player. Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Hello that's a 2010 model set. It sounds like the y sustain board is failing (part # EBR61855101), it usually starts with bad connections on it. A screen shot would be helpful...thanks
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Need some more details the problem you describe could be anything from a simple convergance problem or the light tube going bad in a light engine, one problem about $80.00 to fix the other, slightly over a $1000.00
