Ja jestem za pomocą Google Narzędzia językowe do tłumaczenia. Mam nadzieję, że nie jest zbyt dużo straconych w tłumaczeniu.
Wytrzyj kontakt obszaru na xD-Picture Karta z miękką, suchą szmatką. Może być konieczne sformatowanie xD-Picture Card. Jeśli komunikat o błędzie jest nadal wyświetlany, zastąpić xD-Picture Card. Jeśli nadal masz problem, skontaktuj się z dealerem FUJIFILM.
Mam nadzieję, że ten problem został rozwiązany dla Ciebie. Z poważaniem, CBR2009
How old are your camera and memory card? Both will eventually wear out. Digital cameras are generally good for so many shots. The same goes with the cards. I would personally try a new card and see if it helps.
the camera cannot use XD picture card and multimedia card (MMC). SD and SDHC can be used. for compatibility check this http://www.fujifilm.com/products/digital_cameras/accessories/card/a/
you might need to update your product depending on your serial no.
to format the card, press menu to display menu setup, press right to move to setup 2 (3rd tab) you will see Format. click Format to format the memory ("SD" is displayed if memory card is inserted and "IN" (internal memory) if no memory card. hope this helps
Be sure you have formatted the card, not the internal memory (if the camera has that). Be sure your battery is fully charged, so that the device can fuly write the file. Be sure you are writing the file to the card, and not the internal memory, as there may not be enough space on it to write the file. If this does not resolve the problem, let me know.
If your new xD card is an "H" or "M" type card, it is only compatable with the A340 following a firmware upgrade to the camera. http://www.fujifilm.ca/x3721.xml is a link to the software and steps you can take to perform the upgrade.
