Question about LG VX8300 Cellular Phone
No Application error on new VO4 phone to play my music or sync in VCast
I just received an insurance replacement VX8300 with V04 version. When I download mp3 or wma's to the phone memory or the 2gb card - hit the front play button or select VCast my music, sync or Get VCast Music I have a No Application screen that pops up. I looked through all the forums or blogs and can not find a formula to fix. It's driving me crazy. I've gone through the service code and can't find anything that turns my music on anywhere. Does anyone have a solution??? Thanx in advance!!!
Posted by hak2000 on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: music player and micro sd card
also your songs need to be in special formatted folders. the first time i popped my 4gb sdhc card into my phone, it asked if i wanted to format it. i said yes, and then found that several new folders appeared on the card. one of these is my_music into which you can drag and drop your mp3s using your computer's card reader. just remember not to drag any extra folders or other files that your phone won't be able to recognize.
Posted on Nov 21, 2007
Anonymous
  • 4 Answers
SOURCE: music
Sounds like he has the older version of software for the 8300
go to settings and tools , phone info ,SW version and see if your sw version ends with vo2, vo3 or vo4 .vo4 cripples some functions , v03 is the best in my opinion and vo2 is limited version also . unless it is vo3 take it to your verizon service center and talk to someone real nice and get then to flash it back or up to v03 , will take them about an hour to finish it.
you can also
Try pressing
OK
then the service code
0000000
then scroll to music setting click ok and see if the option to turn on mp3 playback is listed.
Posted on Dec 26, 2007
Anonymous
SOURCE: LG 260 Rumor - Unable to read/play music off memory card
I FOUND THE PROBLEM! You need a CoreMicro Micro SD Adapter and the USB that goes with it. Mine said it was right-protected until a person on a website told me to move a white switch upwards on the adapter. Holding the Adapter facing you, make sure the switch on the left side is moved upwards. Put it in the USB port, and then into the computer jack. Go to WMP (windows media player) and go to your library. Right-click any song and click the "go to file location" button. That way you are at the actual file location and not a link to it for playing. You see a list of all the songs you have at the raw source. Make a folder and name it "Music". Drag the songs you want on your phone into the folder. They will disappear from the menu into the folder but not from the computer so you still have the music files on your computer. With the Music file in view, right-click and go to the "Send to" button and click on the "Removable Storage" button (or something that looks similar but the same words). A loading screen should pop up and start loading the files. You are done! Remove the USB and the Adapter, put the memory card in and charge er' up! It worked for me and i hope it works for you. Thanks.
Posted on Jan 06, 2009
Anonymous
SOURCE: LG shine KE970 MP3 player wont play music from memory card
yes you can, just put the mp3 file on folder "Sound" on the external memory, it will be automaticly put  in your playlist mp3 player.
Posted on May 14, 2009
Anonymous
  • 57 Answers
SOURCE: LG VX 8300 Music on memory card not playing
your songs are most likely in the wrong format
Posted on May 28, 2009
Sometimes the videos play and other times they don't. The media player will load and the video just won't play' Once in a while I will receive an error message.
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, like the error message you receive.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Nov 05, 2009 | RIM BlackBerry? Pearl 8120 Cellular Phone
May 28, 2009 | LG VX8300 Cellular Phone
Putting Music on LG enV
If you buy an SD card for your phone, you can put it in your computer, transfer the songs you want over, and then put it in your phone. The music still plays through VCAST, but you don't have to pay. :]
Nov 17, 2008 | LG enV VX9900 Cellular Phone
Get pictures and video off phone to the computer
Preparation ? if an external Micro SD external memory card is to be used as the desired music/video/picture repository on the W755, install the card in the W755 behind the battery. Then go to SETTINGS & TOOLS ? MEMORY ? CARD MEMORY ? FORMAT and format the new card. Caution: reformatting the card will wipe out all contents on the SD card. Download/install free Motorolla Handset USB Driver Installer onto the PC (execute ?.msi? file). Download/install free VCast/Rhapsody software (no need to actually sign in or use the proprietary Rhapsody service). Start the VCast/Rhapsody software. Turn on cell phone (works with W755 and may work with other Verizon ?music phones? such as LG Chocolate, but the latter was not tested). Connect phone to PC ? connect USB cable to PC?s USB port first, then connect USB cable to phone . Be patient, it may take a minute to fully ?connect? in the phone?s display. Go to ?Sources? section of VCast/Rhapsody GUI screen ? the phone will register as a directory title using a name roughly like ?VCast xxx.? Windows Explorer will also show a ?VCast? drive/directory device. Files can be selected and dragged to and from source and target directories. At this point various options exist regarding music, picture, video management: 1.) The VCast/Rhapody software can be used to manage music, picture, and videos between the PC and phone. Again, no need to use the VCast service, just the software offline. 2.) Alternatively, other music management software such as Media Monkey (a personal favorite) can be used to move music, create playlists, etc. ? NOTE: Leave VCast/Rhapsody software running in the background as a means to ?connect.? It is best to start VCast, then plug in phone, then start other media management software so that the media management software will benefit from the connection (usually with a directory name using some variation of ?VCast.? Then use the alternative media management software as usual. Please note, this is a generalization based on success using basic software like Media Monkey, for example.
Apr 26, 2008 | Motorola Cell Phones
Trouble downloading music to my enV
that was the same problem for me. when you download that vcast software dont use there program. use windows media player 9. that has worked best for me. ive tried the latest window media player out and it doesnt seem to work. but if you use 9 you can go to sync with your phone connected. and you always have to make sure that you go to settings and tools on your phone. then go to call settings and then you should see pc connections and when you get to that you should see usb and you click on that and it should say pc connection set. hopefully any of those options i gave you work out.
Jan 13, 2008 | LG enV VX9900 Cellular Phone
Music
you can also
Try pressing
OK
0000000
Dec 26, 2007 | LG VX8300 Cellular Phone
Message says player error - music is not available?
Your VX8300 can only play .wma files .. so if there's any .mp3 on there it's going to say that. Also, if you recently put on new files try taking them off then trying the card again .. .if that works then one of your new files are corrupt/unreadable
Another thing to try: goto: Get it now .. music n tones....my music ...songs ...options...reinitialize library database. ( Be warned, you may lose some files this way so make sure everything is backed up on your PC)
Nov 30, 2007 | LG VX8300 Cellular Phone
Music to Phone
I've never used WMP to directly sync to my Chocolate. I have success with the VW Vcast software which uses WMP through it. Maybe check Windows's website for troubleshooting on recognizing devices.
Nov 12, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Verizon razr v3M VCAST sync problem
contact your mobile helpdesk carrier
Oct 31, 2006 | Motorola Mobility RAZR V3
LG VX8300 Cellular Phone Logo
75 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
William Norris
William Norris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
