Question about Toshiba Portege 3505 Tablet PC
Need to get into bios
How do I get into bios
Posted by Carmen Lopez on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Hit escape repeatedly while booting. When you get an error message that says hit F1 DO IT. Then you will enter bios.
Posted on Jul 08, 2010
  • rorberson Feb 23, 2011
    that did not work it is as if iam not doing nothing . please help.. i have remove the bios battery. left it out over night . but still nothing
  • Anonymous Feb 24, 2011
    Those are the correct instructions. I've tried it several times. Your bios may be locked. I believe there are jumper settings on the the motherboard that are required to clear the bios if its password protected.
Anonymous
    Guru:
  • 383 Answers
Press F2 or DEL
Posted on Jun 19, 2010
I need reset bios password Notebook HP Compaq 2710p
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some hard tutorials, it is difficult to do. It is better that you are a expert. For example this tutorial: reset BIOS Password?
So I would suggest you the 1st method. Hope it helps.
Aug 30, 2010 | Compaq 2710p Tablet PC
I need to reset the bios on my Compaq TC1000. I tried removing the RTC battery and replacing as HP suggested but that didn't work, They then suggested I need to flash my bios. I cant find instructions for...
To flash the BIOS you need to download the BIOS from a link which HP provides.. so contact them and tell them to provide you with the BIOS link..
You need to download the BIOS and install it..
However after removing the RTC battery I would suggest you to hold the notebook power button for 20 secs..
This should remove all the residua power..
I think it will remove the BIOS password...
If it does not work then you could flash the BIOS..
What sayy???
Jun 25, 2010 | Compaq tc1000 Tablet PC
Reset bios
There's no need to reset your BIOS, only you do is to set in your BIOS Setup to boot priority like for example First Boot Priority is your CD/DVD Rom Drive, if you got some Bootable System Disc then the Second Boot Priority is your Hard Disk Drive. Good luck!
Jul 26, 2009 | Compaq tc4200 Tablet PC
Need to open laptop to pull out bios battery.
I suggest that you enter the Bios setup and choose the option of load-failsafe defaults instead of opening the laptop
May 28, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Lenovo ThinkPad X41 Tablet security chip. lost bios boot password
I have had to retrieve the BIOS password from one of these before. It is not an easy thing to get to. You have to first
  • Build a special 9-pin Serial cable using parts you can find at Radio Shack
  • Dismantle the laptop
  • find the correct BIOS chip,
  • Solder a couple wires to the correct pins of the BIOS chip (without getting solder on the other pins, or damaging something)
  • Hook it up to another computer via serial port
  • Do a dump of the information stored on the BIOS chip
  • Use a hex-reader to decipher the information and display the password within.
Here is a link to a site that shows you in detail how to accomplish this. It does work, and I've successfully used the linked method to unlock a X41 of my own.
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Mar 26, 2009 | Lenovo ThinkPad X41 Tablet PC
Cf-18 toughbook
The BIOS may not support the larger drive at all; I suggest you look for a Toughbook forum and repost there and check Panasonic's site for a manual download and possibly a BIOS upgrade if the unit is equipped with a flash BIOS.
Aug 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
BIOS RESET
There is hack software out there for cracking the BIOS password and resetting, don't take me wrong, I don't get into hacking but where I work at a Uni its a useful tool if used legally
Jan 08, 2008 | Compaq tc4400 Tablet PC
Toshiba Portege 3505 Tablet PC Logo
304 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
