Washer stared to fill & would stop. F1 would appear in window, if I push stop & start a couple of times it would start. Now the washer fills & will not wash spin or drain & now Ld appears in the window. The washer did 1/2 of the cycle washed but would not drain or spin, before it stopped. I have done everthing I know to do please help.
Sincerly
Teri in Oklahoma
I too was having the same problem and I almost paid to have it repaired, which would have cost a few hundred dollars, thanfully I called the recall line after reading some of the other post on here and my machine was elgible for a upgraded on the control panel so didn' t cost anything for us. Sears told us that the F1 code is a miscommunication in the control panel, basically the machine is confused and don't know what to do so it stops and gives that code. Hope it helps!
Check to see if the screens for your hot and cold water connections are plugged with grit. Or else the problem might be due to factory defect in the control circuit board of this washer. You have to replace the board.
Thank you !!
