Question about Video Cameras
My camera lens is stuck in the camera. Whenever i turn it on it says " turn off then turn back on" sometimes it works but if it works when i turn it off and turn it on again it does the same thing!
Posted by danie4546 on
Anonymous
  • 571 Answers
Try taking out the battery and then put it back again. Also a new battery would help.
Posted on Jun 19, 2010
Sony cyber shot dsc h200 lens is stuck, will not take pictures. says to turn off and turn on again, but does not work.
Hi Susan,
If you cannot find the power button, just simply remove the battery wait for few seconds and put the battery back. What I assume of this behavior is 'If the coming out lens is obstructed by anything' the camera will show such error. If it does again, I would suggest calling Sony and getting their advice. Regards
Feb 27, 2014 | Sony Cyber-shot DSC-H200/B 20 Megapixel...
My camera is stuck with a black screen and the lense is half out, whenever I try pressing the on/off button the lense goes in then comes half out again from one press and it won't do anything else
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Jan 25, 2011 | Canon Cameras
Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Jul 28, 2009 | Kodak V803 Digital Camera
"lens error, restart camera"
I was facing the same issue and its working now after following
these steps:
Go to this site http://homepage.mac.com/jpelling/page0/page0.html it will tell you how to take apart your camera and clean out the gear that controls the lens. The instructions are for a different model but it works for the A460 as well. You will have one extra screw to remove on the bottom. Once the gear is free of grit, reassemble the camera and plug the av cable in. This will allow your camera to "reset" the lens by powering on without attempting to focus the lens.
Try this it will resolve the issue....
May 01, 2009 | Canon PowerShot A460 Digital Camera
Lens Error
Hey Joy_2008,
A lens error usually means something is obstructing the movement of the lens (i.e. sand). You could try blowing compressed air into the side of the lens to try and dislodge whatever is stuck in the lens. You could also try placing the camera on a flat surface with the lens pointed up. While holding the shutter button in turn on the camera. What this sometimes does is force the lens to move before the camera shuts down, and when the lens moves hopefully it will dislodge whatever is stuck. If none of this works I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 30, 2008 | Casio Exilim EX-Z77 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Lens stuck open
I have to agree with one of the comments previously posted. I too had a Sony DCS-S700 and the lens was stuck open. Whenever I turned the camera on, the Sony Cybershot logo appeared and dissappeared, turning the camera off. I noticed the lens was crooked, so I moved it in the center direction and the camera worked again.
Mar 06, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Nikon L3 lens stuck
Hi:
Lens errors like this usually happen as a result of something damaging the lens in some way.
It could have been against something to prevent the lens from moving out.
It could have been dropped when the lens was out.
If the lens is impacted when the lens is out, damage can occur.
If there is a buzzing, grinding noise as the lens extends, then the probability of damage to the small plastic gears, internal guides or other internal lens parts is high.
What can be done is, as mentioned a few times in my posts, to hold the lens back or pull on it as the camera starts.
This may cause more damage, and may not help at all, but some cases may re-align the internal parts in the lens assembly. This may be worth a try, since the camera is useless unless the lens works right.
Hope I can give some help here on these.
Oct 26, 2007 | Nikon COOLPIX L3 Digital Camera
Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Oct 05, 2007 | Samsung Digimax S630 Digital Camera
Video Cameras Logo
Top Video Cameras Experts
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Video Camera Expert? Answer questions, earn points and help others
