MY CAR'S AIR CONDITIONING ISN'T WORKING. MY SON IN LAW PUT IN TWO (2) 12 OZ. CANS OF 134A AND IT STILL ISN'T WORKING. ABOUT (4) FOUR MONTHS AGO, THE BLOWER STOP WORKING AND I HAD IT FIXED BY A REPUTABLE REPAIR SHOP. THE BLOWER WORKED FINE AT THAT TIME--IT WAS COOL, SO I JUST USED THE HEATER AND DIDN'T THINK ABOUT THE AIR CONDITIONER, SO I DIDN'T TRY IT THEN. WHEN IT STARTED TO TURN WARM OUTSIDE, I PUT THE AIR ON AND ALL I GOT WAS HOT AIR. FOR THE PAST MONTH, I JUST DIDN'T EVEN TRY AND USE THE AIR CONDITIONER, UNTIL TODAY. WELL, LIKE I SAID--HE PUT REFRIGERANT IN, BUT THERE WAS NO CHANGE IN TEMPERATURE.
ELDORADO Refrigerant Capacity and Refrigerant Oil Type
1998-02 32.00 Oz. R-134a; 9.00 Oz. PAG-150; w/ OE Harrison Compressor 1998-02 32.00 Oz. R-134a; 9.00 Oz. PAG-46; w/ Denso Compressor.
1994-97 32.00 Oz. R-134a; 8.00 Oz. PAG-150; w/ OE Harrison Compressor
hi
this should do it
thanks
2008 Chevrolet Aveo L4-1.6L
Heating and Air Conditioning Specifications, Capacities: Refrigerant System Capacities (V5 System)
If you have front and rear air you will need 2.2 lbs of R-134a. If you have front air only you need 1.68 lbs of R-134a. you will also need to use pag oil to refill the system, front and rear system uses 7.77 oz of pad oil and the front only system uses 7.1 oz of pag oil. These are for a dry system, if the system has not been drained and cleaned then you will need to use less depending on the amounts in the system.--------------Click this link below for car troubleshooting problems:--- http://schematicsdiagram.blogspot.com/2011/06/car-troubleshooting-guide.html
Thanks.
It depends on what size cans of freon you are getting and if the system has been retrofitted for R-134A refrigerant (1992 came originally equipped with an R-12 system). The factory specifications call for 1.8 Lbs. of R-12. If it has been retrofitted for R-134A, the general "rule-of-thumb" is 85% of the R-12 specification is needed to charge the system with R-134A. So if we do the math: 1.8 Lbs (R-12) X .85 (R-134A) = 1.53 Lbs. R-134A needed for a full recharge (providing the system is COMPLETELY empty. Then you will have to find out how much is in each can that you plan to buy and do the math to figure out how many cans you need. (some have 12 oz., some have 14 oz., some have 16 oz., some have 19 oz. and some have 22 oz.)
first you need to find out why the freon leaked out then repair that, then you will need a vac pump to vacuum the system for about 45 mins then if you lost oil add a couple of oz,when you lost the freon if there was a cloud of oil and gas then add 2oz before the vac down while system is open put into line or dryer or condensor, after the vac, then recharge to spec, there a label at the radiator support or on the hood that tells you how much freon the system holds,here you go it holds 1.48lbs of 134a freon.
check the service ports if they are screw type it is r 12 if they are quick connect type it is 134a yes you canconvert it i do it all the time
go to autozone or oreillys and get a retro kit (a little box of fittings) about $7 3 cans 134a and ester oil vacuum system down with pump for 30 min add 2 oz oil and 2 1/2 cans 134a.
On a 1999 s-10, your correct refridgerant is r-134a. I don't understand why wisconsin won't allow you to purchase r-134a at a auto parts store. R-12 is the refridgerant that has been banned in the US, and requires ASE air conditioning certification to purchase. I've never heard of any law anywhere prohibiting the purchase of r-134a.
Anyway, your system is a r-134a system.
I hope this helps you, and I wish you luck on your repair.
