My son's dvd player is now saying region error for ALL dvds. They were playing fine previously...I don't know if he touched a button or something...how do I fix this?
1. Power ON the main unit (some unlocks work with, some with no disc inside) 2. Press the SETUP button (on the top of the player) to open the setup menu 3. Navigate to the PREFER menu using the button below the screen 4. Press NEXT>, PREVIOUS, NEXT>, PREVIOUS, NEXT>, NEXT>, aPREVIOUS
(NEXT> and PREVIOUS are on the top of the player next to the SETUP button. Don't use the menu navigation buttons below the screen for this.)
5. The current Region of the player should be displayed on the screen
6. Use the menu navigation UP/DOWN buttons (below the screen) to change the region. Region 0 is region-free.
7. Press PLAY/OK (below the screen) to confirm the region selection
The player should now be unlocked and able to play discs from all regions - it worked on my PD9012/37 that was region 1
Please note: Unlocking a DVD player may invalidate the warranty and some DVD players have been damaged through failed attempts to unlock them. Unlocking the DVD player is attempted at your own risk.
The DVD player is region locked and will only play DVDs from a particular region. The cheap DVDs are probably region 0 and so will work on any DVD player. You can scour the internet for a code hack to change the region (I've had a quick look and not found anything).
no solution but i have exactly the same problem - the system has suddenly stopped playing any dvds at all including ones it has previously played - i get no sound or picture just a circle with a + sign in the middle on the dvd digital display
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all
regions
8. Press the "Play" button on the remote
you may have a different region on you dvd to your dvd player. say your dvd player was 1st region you can only play 1st region dvds if you try a 2nd or 3rd region dvd it would not work. you can go to a dvd specialist to get it tuned to a multiregion dvd player.
go to a dvd player shop and ask if they know how to tune it.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
