Question about Tomtom GO GPS Receiver
How do I get my tomtom off walking mode
My tomtom changed from showing driving time to walking time and I don'tknow how to set it back.
Posted by frank_galano on
Will Halftowaite
  • 508 Answers
Go into the submenu system, check that you didn't change it from car to walking, if you didn't then keep going through the menus you will eventually find a setting in there of what you want to display in the corners and you should be able to change it there. Process will take you awhile to find the right menu, but you may be able to find it in the manual quicker. Hope this helps
Posted on Jun 19, 2010
Why tomtom seems I changed the battery it's not working
The screen shows an X when the navigation software on your TomTom is corrupted ... and it will not start (boot) up the device.
Have you tried contacting TomTom Support, to have them walk you through this problem ? assuming you recently bought your TomTom and it is still on warranty.
Jun 07, 2015 | Tomtom GO GPS
Tomtom instruction manual
Change Settings > Route Planning > Default Route Type
Re From Walking mode to driving mode
Jul 17, 2014 | Apple iPhone Smartphone
How to fix upside down screen on led tv
Time control board or lcd panel itself. Some times you cannot get the t con board. it may only come with the LCD panel. Check Shop Jimmy website.
May 29, 2013 | Vizio E390-A1 39" 1080p 60Hz LED 2.95"...
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    I need to reset my tomtom clock from A.M. to P.M. It's a 340-S
    i have a tomtom one, not sure if they are all basically the same, but try this. you should be able to via the settings menu. tap screen, tap 'change preferences' and scroll through the screens until you see 'change time' use the little arrows to set the correct time, and then select 24hr mode. if you are not happy with 24hr mode then select 12hr mode. if you know it is pm but sat nav is showing the correct time but in am, then simply increase the hours by 12.
    Aug 05, 2009 | GPS
    Hi go 720 activation code problem
    Activation code will be on a small card in the box.
    Apr 01, 2008 | Tomtom GO 700 GPS Receiver
    Tomtom - time of arrival
    It is possible that you have the TomTom set for "walking routes" or "bicycle routes" or "limited speed." (I have a TomTom One 3rd edition, so if you have a different model the menus/icons may be different, but it's worth a shot.)
    Click on the main part of the screen, while on the main navigation screen. Then click on "Change preferences." Then click the blue arrow to scroll to the Preferences 3 of 5 page. Click on "Planning preferences." Choose the planning preferences that you want. Hope this helps...
    Nov 11, 2007 | Tomtom ONE GPS Receiver
    Tomtom GO GPS Receiver Logo
    526 people viewed this question
    Top Tomtom GPS Experts
    k24674
    Marvin
    Marvin
    Michael Thomas
    Michael Thomas
    Are you a Tomtom GPS Expert? Answer questions, earn points and help others
