Question about Sylvania DVR90VE DVD Recorder/VCR
Machine keeps saying "disk ERROR " even on new bought DVD's???
Posted by adltokers200 on
Rylee Smith
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check that the DVDs are not scratched. Now run a lens cleaning DVD. If that does not work then you have to open the unit and clean the lens with a Q-tip dipped in alcohol. This is only recommended when the unit is not under warranty and you have some expertise in the field. If still the issue is not resolved then the lens is required to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 18, 2010
Need to reboot computer,windows98,invalid disk error
You have to go into your BIOS and select booting from Disk not hard drive when i say disk i mean either the cdrom or dvd disk players attached to your motherboard. also you can get a boot disk to try that at the link below.
http://www.allbootdisks.com/download/98.html
Apr 07, 2012 | Computers & Internet
Won't format new DVD-RW disks
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
Sep 18, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
The dvd player takes the dvd but says
If it does it with a shop bought dvd then there is a strong chance that there is a fault on the unit.
If however you are using home made dvd's cd's'then that is a different situation and you should double check your source burning capabilities.
Aug 13, 2009 | Polaroid FLM-3201 Television
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
I have a Magnavox MWR 20v6, I keep on getting error messages.
I figured how to get the Memorex DVD-R's working again. I went and bought a DVD lens cleaner and all the errors stopped at least for a while I hope.
May 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Problem with DVD/VCR RCA DRC8335
More than likely the DVD drive in your unit is bad.
Feb 27, 2009 | RCA DRC8320 DVD Recorder/VCR
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
I can't play any DVD's. It keeps saying cannot read.
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Panasonic DMR-ES25 DVD Recorder
Can't get past LOAD
it might need to be cleand u take the sheild off and take a q tip and lightly clean the laser
pls rank ps keep off the carpit
Jan 23, 2008 | Samsung DVD-VR357
Cannot finalize new disc???
are you sure there are the correct disk , i had problem where i tried to use dvd instead of cdrw or cd-r
Jan 07, 2008 | Sony Mavica MVC-CD400 Digital Camera
Sylvania DVR90VE DVD Recorder/VCR Logo
47 people viewed this question
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
