Printer Setup & Support Call 1-(805) 225-6690 We are 24 Hour Available Call Now For Help
I want to add Free to Air channels on a dstv decoder (DSD 1110 +2), what can I do?
Posted by mobarisayo on
  • Anonymous Mar 18, 2014
    what programs are there on dstv select 2
  • Anonymous Mar 24, 2014
    is this decoder hd
chimamy
    New Friend:
How can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Posted on May 28, 2012
Elizar Murro
    Sergeant:
    Champion:
  • 310 Answers
Just go to menu and click arial ant and press auto program its automatically reprogram it store all channel
Posted on Jun 18, 2010
Augustine5fi
Please help me with the dstv code. the one i have is 4 free to air. I am using DSD 1131 [email protected] i am from nigeria
Posted on Jun 05, 2012
How to install prophet bushiri channel on dstv
PROPHETIC CHANNEL SETTINGS on Your DECODER(DSTV)
Step: 1 Press menu Select "Advanced Options" Select "Dish Installation" Enter the pin "9949"
Select "Network Configuration" Select "Network 2 Setup" NB: Leave "Network 1 Setup (Home)" unchanged!! Set Signal Setup to "Enabled" by selecting it, and moving left or right Set Frequency to "11170" Set Symbol Rate to "26652 Set Polarization to "Vertical" Set FEC to "3/4? Select "Accept these settings"
Step: 2 Select "Network 2 Setup" Set Signal Setup to "Enabled" Set Frequency to "12682" Set Symbol Rate to "26657 Set Polarization to "Horizontal" Set FEC to "1/2? Select "Accept these settings"
Step: 3 Select "Network 3 Setup" Set Signal Setup to "Enabled" Set Frequency to "12722" Set Symbol Rate to "26657 Set Polarization to "Vertical" Set FEC to "1/2? Select "Accept these settings"
Step: 4 "Accept these settings" to go back to the "Dish Installation" menu then Select "Scan All Networks" Your decoder will go into scanning mode and might take a while to scan all networks. Do not interrupt the process even if it seams to take longer than you expected! Once completed, your picture will return as normal.
ENJOY WATCHING PROPHETIC CHANNEL.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Nov 19, 2016 | Televison & Video
What can be the problem if my Dstv decoder model DSD 1131 doesn't have signal strengh or signal quality I'm staying in Pretoria how can I fix the problem
The best that I can give you is at this link:
http://hopeafrica.tv/index.php/component/content/article/40-schedules/202-dstv .
It should be noted that Africa does not have digital tv so you should probably hook an antenna to the tv without the box and have the tv search for analog tv stations as that will stand the best chance of picking up what few channels they do have.
Good Luck!
Rich Lilja
Jun 12, 2015 | Televison & Video
My decoder Dstv dsd 3u doesn't response to the remote what should I do cause i need to add volume
If you have extra batteries, try to replace the old one and install the new batteries. And if still doesn't work, try to clean the battery terminals of the remote control, because sometimes, those are the one that making the problem due to corrosion caused by leaked batteries.
Aug 04, 2014 | Televison & Video
How do I setup 2 tv,s on a single view dsd 1131 decoder, 1 tv and decoder upstairs an 1 tv downstairs. The dish is already installed and can rust very easily for the area.
very simple ,, the tv next to the decoder must be conected using a rca cable and then run normal tv cable (RF out ) to the other room
Apr 04, 2013 | Televison & Video
Is it possible to unlock dstv channels by entering the codes?
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 27, 2012 | Cell Phones
How to unlock e.tv in mytv decoder and how to open scrambled channels in DStv?
How to unlock etv and scrambled channels on Mystrong Decoder
Nov 15, 2010 | Televison & Video
Televison & Video Logo
1,973 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
