Western Digital My Book Home Edition 500 GB USB Hard Drive Logo
Posted on Jun 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Winwos doesn load freezes
Pc beeps and dosnt load windos
Anonymous
Level 2:
Scholar:
  • Expert 96 Answers
  • Posted on Jun 18, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
96
Questions
0
Helped
32905
Points
285
How many beeps... what kind of pc? below is the standard beeps codes with the the issue.
Standard Original IBM POST Error Codes 1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
2answers
Dosnt turn off says on but if you press any button it just beeps
bad control board maybe u can reset the applaince? try turning to off position pull out knob then unplug for a couple minutes then plug back in then lift open and close lid slightly 6 times within 12 seconds - good luck
My dell inspiron beeps 20 times at sturtup
I wonder if you have a keyboard issue. Most times the constant beeping means the keyboard is bad, but it doesn't normally boot or revert back to 5 or 4 beeps.
Microsoft office
i lost my winwos licenc key . now how i register my product ?
T2865 Starts to boot but freezes at diff.stages- no beeps
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot. After reboot your problem should be resolved.
I turn on my computer. it starts to boot. then blank screen. nothing. it dosnt load into windows nothing. even my mouase dosnt work but it's on
Turn off computer. Now turn it on, and as it is starting hold down the F8 key. you will hear a beep and ket it go. A set of options will come up and choose Safe Mode with Networking. if it manages to get to windows you are fine.
If not, hit fn key + a key with a smzll monitor (usually one of the F keys at the top, like F5 or F6). It might have been put on display mode and woukd onky show if connected to a projector, tv, or external monitor.
Dell 1545, i turn it on and it sounds like it starts but it dosnt, then after 4 mins it beeps, 4 times like beep beep beep beep lol! it loaded up once but crashed when i tried to restart it? whats the...
4 short beeps means the system timer on the motherboard is bad. You can try reseating the power connectors on the MB and resetting the CMOS memory but it's probably the motherboard. DELL'S QUALITY HAS REALLY SLIPPED!
Freeze
Sounds like the OS is currupt and you will need to boot with your restore cd which you received with your system, and set everything to factory default.
Good Luck.
Not able to upload PC SUIT in windo vista
Please down load latest version pc suite and try to install
2answers
Cant connect wireless router
you have to first attach to the router thru your wired interface first.
Then you can setup the wireless interface
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
