Zassyway
I have provided instructions on how to program the remote to your TV. I have also provided codes for your TV brand.
Remotes: Basic (Television Only)
The codes are as follow: 720, 220, 748, 721 (694 only has a 2% success rate). I hope this helps.
Ray Calo
DISH Network
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
