Question about OKI C5500n Printer
I have a c5500n oki it was showing 980 fatal error. I check the fuser and it had a piece of paper stuck in it.I got the paper out and it still show 980 fatal error. What else can i do? Is the rollers on the fuser suppose to be stiff and hard to turn?
Posted by meoma2 on
john smith
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
If you want technical support of Okidata, you can contact us on Okidata Customer Service 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/d2sZbZ
Posted on Aug 08, 2017
Smithmkt
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 68 Answers
If you need oki data customer service number, then you can contact with us, okidata customer service [email protected]@[email protected] are always here with tech team for your help. For further Info Click:https://goo.gl/Ltis3S
I have a c5500n oki it was showing 980 fatal - slide2-n3tluy4phvp2osrhnzvrn4cg-2-0_1.jpg
Posted on May 11, 2017
Anonymous
    New Friend:
I've replaced the fuser after receiving the 980 notice, but still says 980 fatal error. Are there any resets for this i may be missing?
Posted on Jul 22, 2011
Dominion Computer Solutions, Inc.
    Champion:
  • 312 Answers
Sounds like the fuser is defective. You shoudl be able to turn it easily
Posted on Jun 18, 2010
I have am Oki Data C6100 and I just got a 980: FATAL ERROR message. I replaced the fuser about a month ago and now it is showing up again. Last Wed I had a paper jam several times. I took out the jammed...
paper jam is a main issue in printer when you clear the paper jam normally a tiny piece of paper falls into the printer and the printer get stuck again to clear the printer of tiny piece remove the toner and use a light blower and blow away the piece of paper this should be done only after removing the power and the usb from the printer after cleaning connect the power and the usb and restart your computer
Jun 28, 2011 | OKI C6100n Laser Printer
OKI C5500
Error 980 means media clinging to the fuser,remove the fuser and see if there is something wrong in it
Jul 07, 2008 | OKI C5500n Printer
My printer model is OKI C5600n. On the displey stay message: Call services. 980:Fatal error. Where is a problem ? Whats is possible doing now?
Error 980 means that there is something stuck to the fuser. Check to see if there is something is stuck in the fuser. If you can't clean it out, then you will need to replace it.
Mar 22, 2011 | OKI C5500n Laser Printer
980 fatal error chech for paper pieces and all
unplug printer get air in can and blow out real good then plug back in.
Feb 24, 2011 | OKI C5500n Laser Printer
I had a piece of paper wrap around the fuser of my Oki C5650 printer. I have removed the paper (all of it.), but now it is displaying a 980 Fatal Error code. What do I do now?
I just had a service call with a 980 error. i removed the paper wrapped around the fuser roller but the error persisted. The only thing that cleared the error was to replace the fuser. I am not sure why but the fuser was shot after it had the paper wrap inside it.
There is no reset to clear the error. The only fix was to replace the fuser.
Aug 18, 2010 | Office Equipment & Supplies
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on [email protected] and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
OKI C5900
we have the same problem but with Oki c5500
Jun 13, 2008 | Office Equipment & Supplies
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
OKI C5500n Printer Logo
2,553 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
