Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Posted on Jun 18, 2010
Can we use canon ixus 75 as a webcam
I always wanted to take pictures using my computer and a saw a program clled raw image or samething like that but when ever i open it it gets closed automaically so please tell me how can i take images using my computer in Canon IXUs 75
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Jun 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
2150
Points
13
A raw image is an uncompressed format your camera takes the picture in. Usually it gets transferred from the camera into a .jpg compressed format to your computer (which simplifies everything and is able to be viewed by anything like photo viewers). I would search for a canon IXUs 75 driver for your computer, and turn your camera 'on' plugged in with your USB using a standard computer photoviewer program to see if it has a live mode?
How can i take a picture of myself in canon ixus 75
Go to settings and see if it has a timer if so position the camera where you want it hit the picture button get in position and smile
2helpful
Can i use my canon digital ixus 75 camera as a web cam?
Many people ask if they can use their digital camera as a webcam. In the early days of digital imaging, it made sense to dual-function a camera because a webcam was a serious investment. However, webcams are now so inexpensive that manufacturers are not considering this functionality important in their digital cameras. In fact even the word 'webcam' creates the impression of bad imaging, so associating this function with a camera actually makes the camera seem 'cheap'.
Your camera is actually quite a new, and a nice camera. It doesn't make a lot of sense for Canon to make it work as a webcam, because it's a waste. And in any case, you'd expect a webcam to be powered by a wall outlet or the USB... but most modern cameras like yours don't come with adapter-power, they have battery chargers instead. And they take too much current to use the USB power. By the time they'd added the extras to make it work properly as a webcam, you could BUY a USB webcam separately.
Anyway, back to your question... so, can your camera be used as a webcam? Probably not, but here's how you can tell. Make sure you've installed all the software you can find for your camera, power it up, and plug it in. Windows will tell you if it has a webcam function. If it's a webcam, then it will appear in "My Computer" as a device, right along with all the disk drives. To be sure, go to your control panel and select "Scanners and Cameras". Is your camera listed? If not... it's not a webcam.
In the unlikely event that you have a 'video in' on your computer, and that your camera has a 'video out' then you can follow the instructions on the sony site ("how to use a digital still camera as a webcam"); but most people will not have that yellow 'video in' connection.
Sorry this wasn't the news you really wanted.
How to download pics from Canon ixus 75 to my new desktop
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon's ZoomBrowser or any other photo cataloging program.
How to use the canon ixus 75 as web camera
The SD750 cannot be used as a webcam. It was designed to store images and videos to memory, not to stream live video to another device.
Sorry that wasn't the answer you wanted to see, but there it is.
How do I turn the date stamp on canon ixus 75 ? want the date printed on front of my pics.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Hi how can i turn on date stamp on my canon ixus
I want to put my photos from my canon IXUS 75 onto the pc
Are you using a memory card or internal memory? If you are using a memory card, get a memory card reader and download the images onto your comp.
Ixus 75
Your camera will datestamp your photos only in "postcard" mode.
However, the date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
2answers
Unable to download images to computer.
You will need something to view the JPGS with.
XP should find the right program....if not
click START, MY COMPUTER, TOOLS tab, FOLDER OPTIONS, FILE TYPES, see if JPG is there, if not click NEW, if it IS there click the CHANGE and use the XP Window PICTURE VIEWER.
Then you are set.
Good Luck
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
