Polaroid i832 Digital Camera Logo
Question about Polaroid i832 Digital Camera
Why are my pictures somewhat blurry. What setting
Why are my pictures somewhat blurry. What setting keeps this from happening? If it's set on portrait the pics are better and clear, as long as no one moves even a tiny bit. If regular setting it always flashes but isn't always a clear picture...blurry sometimes...what do I need to set it on to prevent this blurriness?
Posted by ron_dean_hay on
5 Related Answers
Anonymous
  • 450 Answers
SOURCE: Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Posted on Sep 14, 2005
Anonymous
  • 7 Answers
SOURCE: every single picture i take is blurry.
Have you set a manual exposure time in the menu ?
Clean the lens!
Ensure iso is set to auto.
Posted on Aug 21, 2009
Anonymous
  • 2178 Answers
SOURCE: My pictures are very blurry.. We have reset to the
The auto-focus might be bad. Set to manual focus and see if that works. If not, then the focus motor is slipping or the motor itself is bad and cannot focus the lens properly.
Posted on Nov 03, 2010
Anonymous
  • 11967 Answers
SOURCE: When taking close up pics, of say a pencil on a
Why are you against going into macro mode? That's what it's for. Also, either use a tripod or set your camera on a firm surface.
Posted on Jan 24, 2011
Anonymous
  • 6 Answers
SOURCE: pictures are always blurry
Push the shutter release button half way to focus the picture, placing the subject in the center of the frame.
If this is not working, the lens in your camera may be damaged, needing professional repair or replacement.
Posted on Mar 12, 2011
Picture keeps blocking on led tele
Do you mean you get large blurry blocks (pixellation) where and when there is a sudden change in the picture? This can happen when the video processor is unable to keep up with the material. Perhaps you are trying to watch 720p material with the resolution set to 1080p, or vice versa (the extra conversion step takes more processing time). Try changing the resolution. Also, try an interlaced format (720i or 1080i) if that is available on your set.
Generally, you will get the best results if you set the resolution to be the same as your LCD panel (most of the larger ones have 1080 lines, but the smaller sets usually have 720 lines). Check your owner's manual for more information (if you can't find it, look it up on Samsung's support page for your model.
Even I'm facing the same problem "I have a Nikon Coolpix s70 camera that I just recently received for Christmas. I cannot seem to figure out the best setting to put it on to take good pictures. They...
first of all i wanna ask one question, does your camera fell from your hand? usually this comes when your optical zoom motor is not responding to signals receiving from cameras processor. better service it with nearest service centre.
2answers
I have a Nikon Coolpix s70 camera that I just recently received for Christmas. I cannot seem to figure out the best setting to put it on to take good pictures. They come out blurry and somewhat grainy. ...
Check the manual for instructions on how to set it for the maximum number of megapixels and the best picture quality. If it has shake control, be sure you have it on. Set the camera to "auto" everything until you become more familiar with it.
My pictures are coming out blurry?
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its happens. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there
is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks
Pictures blurry
Hi Karen,
Had the same thing happen to me. Drove me nut's for a while.
What it turned out to be on mine was a tiny scratch on the lens. I found it with a magnifying glass and bright light. I guess it was in just the right spot to blur the pics.
I was able to get mine replaced where I bought it.
If yours is still under warranty, definitely exchange it.
But if not, look closely at the lens. If it's fine, we keep looking for the problem
Best regards,
Mike
Blurry pictures after I have had no trouble in the past
If this is happening only in low-light situations when the flash is not on, check your manual to turn the camera's high-sensitivity feature on. Or change the ISO to the highest setting (1000 is good) for these pictures. That should reduce blur and shake. Of course, putting the camera on a tripod or beanbag, or resting your elbows on a solid surface, will have the same effect.
Lines and blurry screen
hi, sounds like u need some solder joints re-worked (probably quite a few for a set that old, but your right it`s a great set), price varies by region greatly, I`m in central florida we would charge 75 for service call & 95-125.00 for labor depending on how long it takes to do the solder rework, hope this answers your question, get it fixed it`s waaay better than the new hd (ha ha ha) sets, video-tek
Blurry pictures
try turning of the stabilizer if you have one it will be in the settings menu
1helpful
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Steve
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
