Question about Samsung HT-Z310T Theater System
My HT-Z310 surround sound says protect
When i turn on the surround sound it says hello and then it says protect and then does nothing
Posted by eddiejoplin on
Anonymous
  • 37 Answers
The amplifier has a bad channel, the power supply is bad, or the amplifier is drawing too much power.The speakers could also be wrong, if they are not the speakers that came ith th unit, they will need to be replaced. (Any speakers within the specs of the amplifier will work, so to that end the system is customizable. You can go to Samsung.com to find the amplifier's wattage per channel, but the speakers you get MUST be 3 ohms impedance.) I have an article/tip/how-to as to wiring multiple speakers to one channel.
Posted on Jun 20, 2010
  • Matt Hale Dec 21, 2010
    what a bunch of ****. my system does the same thing with nothing attached. samsung will attempt a repair for $160. A new system is a better idea. Best idea is purchasing another brand in the first place. spread the word.
  • Vickramsing Sowdagur
    Vickramsing Sowdagur Jun 06, 2016
    Rubish answer......my htz310 same problem
    PROTECT......i thing that samsung has created this product to earn money from poor.....what a shame samsung......its the ic audio amp that creating this problem........i have to change the board which cost 4500rs ........better buy a new panasonic product .....shame on samsung product
2answers
I have a samsung HT-Z310 home theatre. I left plugged and when light was restored the power ic blew. So i replaced and the power came back on but immediately it comes on it say protect.
That's the power supply board isn't it. Have you checked the main power amp board? For when the power board failed it might have taken out the main power amp with it!
Sound from Onkyo CD player well and fine. Then connected the Samsung DVD HT-Z310 to Video3 (L/R audio in, V-in from L/R Audio out and V-out of Samsung) but no sound or nor video on TV? Tried to fix it...
What am I missing here?
There are a lot of models mentioned in this post. What are WE discussing?
* A Samsung HT-Z310 is a Home Theater System.
* An Onkyo TX-DS777 is higher-end AV Receiver that DOES have a Video 3 input which accepts composite video and analog audio.
* An Onkyo CD player is irrelevant to the TV sound in any scenario.
* Unnamed TV.
I don't see any path in your narrative that would carry audio TO the TV. Is there an unmentioned HDMI cable in here somewhere? I see no other audio outputs on the HTZ.
Are you running the HT-Z310 through an Onkyo receiver to somewhere (?) else?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-Z310-Home-Theater-Systems-manual/id/23122dj393/t/2/
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
2answers
I have a Samsung HT-Z310 surround sound system. I've had this machine for about a year and a half. Just recently, I've been getting the "Fan Check" message on the word display box. I took the cover off of...
I just got finishing chatting with a customer service person on the Samsung website and it seems that yes a new fan is necessary. I was told to register my surround sound and then place a service request to find an authorized service center. I
I found the fan on amazon for about $7, so I plan to buy one and install it myself.
1helpful
Digital In on Samsung HT-Z310 no sound
Optical into your XBOX 360? If there is a connector that you are using to convert it, I was start by replacing that.
Surround sound hok up
try using a HD plug in cable that should solve ur problem
Hello and thank you in advance for helping me resolve this.... i have a insignia 52 flat screen tv.... i just installed a samsung ht z310 home theater... i tried everything and i cant seem to get the sound...
have you connected the optical cable. as the only way to get sound from the tv to the surround is via that link. the hdmi cable only send video and audio to the tv not both ways for some reason.
3answers
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Samsung HT-Z310T Theater System Logo
Top Samsung Audio Players & Recorders Experts
 Francisco Mauricio...
Joaquim Martins
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
