2 years is generally about it for the battery on the C330. You most likely need a new battery. Charging it on or off does not matter. Run it with the back light on a dimmer mode to increase battery life for now.
Try to charge the unit for 4 hrs by using a wall adapter and then try power on it again and if still the same after you full charge the unit try to contact the manufacturer check if there is a latest firmware update for the unit.
If you left your Garmin c330 on running
the battery will have 1% life left. If you turn c330 back on again, it
will flash screen for 3 seconds then die, even charging it at this
point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the
power home or car into Garmin c330. There is a tab in the front Garmin
gray frame of your screen. You must take like your fingernails and
under the logo "GARMIN" pull the whole gray plastic frame off.
Underneath the plastic frame to the right hand side. There is a "RESET"
button. Make sure power is plugged in while hitting reset. Your battery
should come back to life. Cheers
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
take off the front face plate. hit the reset button on the right. charge it.
I've got a 320. Same thing happened. On the 320 if you look closely there is a fingernail shaped indent on the inside of the square colored face plate. just pull the face plate towards you and it will come off with very little effort.
