does it just beep and is not reconized by your P.C.? if so continue to read,
If you get no joy using the Troubleshooting Guide then try this...
don't worry if you are a novice like me, the thread is very easy to follow.
Look inside your P.C. 1st to check SATA data connection type.
eSATA is a different connection from SATA so you might need an eSATA data lead if you follow the guide in the link, not sure if it just external connections only and plain SATA connection inside.
Google image 'eSATA' data lead/cable and you will see the difference between the eSATA and SATA connection if you don't already know.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread....
http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
