Barbeques Galore Turbo STS 4-Burner with Rear Burner 172449 (LP) Grill Logo
Posted on Jun 17, 2010
Turbo STS grill, converting to propane from natual gas, orafices arn't available from Turbo
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 02, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1258
Points
I would like to convert my Turbo STS grill from propane to natural gas. Where can I find the correct sized orifices?
How i can convert Torbu sts 4-burner sts grill from natural gas to propain
To convert the fuel type for any barbecue the regulator has to be changed and all the prefaces have to be changed.
The regulator and the orifices must be purchased together or at the same time because the hole drilled in the orifice is dependent on the amount of pressure allowed into the manifod by the regulator.
Grill isn't flowing propane when tank is on. No smell of propane and starter is clicking. Tested 3 tanks on grill and no luck. Tested same tanks on another grill and they work fine so it's the
it could be the reg or a blockage in the line or open the taps on the grill then close them reconnect gas tank open slowly then tis if there is gas to grill
1helpful
Can a Turbo STS 3 burner grill (720-0057-3b) be convert from natural gas to propane? Barbeque Galore has gone bankrupt and does not offer any assistance at their 1 800 number and I can't find any...
The original BBQ's Galore went bankrupt, but was bought by new owners, who still operate it as BBQ's Galore. However, they did buy any of the older company's parts supply. However, all you need are the burner orifices for each burner (including the rear burner) and a Hose/Regulator Assembly to connect the grill to the grill tank. Follow the conversion instructions in the Owner's Manual (see link below) and you should be able to do it.
http://www.grill-repair.com/images/grill/turbosts.pdf
I suspect if you call BBQ's Customer Support 800-752-3085. They can provide the orifices, as they are universal in fit. The Hose/Regulator Assembly can be purchased from any hardware store or home improvement center that sells grills and accessories, for about $30.00.
Once converted, you will see marked improvement in the heating capacity of Propane Gas, as opposed to Natural Gas. The grill will preheat faster and maintain higher temperatures longer.
I hope this helped you, Bradley and thanks for choosing FixYa. Happy Grilling!!
3answers
Can't find a natural gas regulator for a BBQ Galore 4 burner slide in grill. Believe it is a SST ( or sts) Turbo model. Any suggestions on what might be a valid substitute? Grand Hall ( the parts...
I assume you have already check with BBQ's Galore ( 800-752-3085 ), as they usually stock conversion kits, if that particular model is approved for conversion. Also, you will need 4 new Natural Gas Burner Orifices. The Propane ones will not work satisfactorily, if at all.
Hope this helped and Happy Grilling!!
2answers
I have a Turbo Elite 3 burner barbecue. Want to convert it from propane to natural gas. Where can I get a conversion kit?
Your best bet is BBQ's Galore. Since it's their grill, if there is a conversion kit for that model, they'll have it. However, not all gas grills are convertible from one gas type to another.
Apr 01, 2011 • Grilling
1helpful
Convert propane dryer to natual gas
You need the NAT gas orifice and the stem under the cap on the burner needs flipped over
Converting to gas
If it does not get hot enough when using natural gas then the small propane orfices must be sized larger for the equivalent BTU rating of propane. Conversion tables are online via Google
Top Barbeques Galore Grilling Experts
Paul Carew
john h
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
