Question about Wolf Range WKGD-2 Gas Double Oven
How do i clean the inside of my wolf gas oven it is not self cleaning
3 Related Answers
Anonymous
  • 338 Answers
SOURCE: how to clean gas wolf oven
No. Because if you dont get all the cleaner off you dont know if it would be toxic or not.
Posted on Jan 16, 2009
Anonymous
  • 93 Answers
SOURCE: How do I clean a Wolf gas oven? Can I use
Wolf does not recommend use Easy Off, but this is the best cleaner for oven, just don't spray on it, wear gloves, spray on a rag and apply on to the porcelain surfaces, and other good all around cleaner is called Bar keeper's friend and you can pick it up at Safeway or ACE Hardware. Have fun.
Posted on Mar 02, 2010
Anonymous
SOURCE: I cleaned the top oven of my WOlf stove and the
did you happen to figure out how to fix this? we have the same problem
Posted on Mar 06, 2010
Directions on gas self cleaning oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 24, 2010 | Ovens
My self cleaning oven didn't get clean at all. The cycle went all the way through and cooled down. There are brown drips on the inside of the door.
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 14, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
How do I clean a Wolf gas oven? Can I use commercial oven cleaners?
Dec 31, 2009 | Wolf Range WKGD-2 Gas Double Oven
I have never used a self cleaning oven.i have already put oven cleaner on the inside and let it stand for awhile is this right? god I don't want to blow up
You DO NOT use a oven cleaner with a self cleaning cycle. Wipe out the oven cleaner as instructed on the can. Oven cleaner is better than self clean cycles anyway. Most self clean cycles eventually cause oven control problems.
Oct 08, 2009 | GE JGRP20 Gas Single Oven
Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 26, 2009 | Wolf Range WKGD-2 Gas Double Oven
How to clean gas wolf oven
Jan 16, 2009 | Wolf Range WKGD-2 Gas Double Oven
Wolf Range WKGD-2 Gas Double Oven Logo
275 people viewed this question
Top Wolf Range Ovens Experts
Harjeet s. bola
Harjeet s. bola
ray gallant
jenifer ronan
jenifer ronan
Level 1 Expert
Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
