Hi, I went to the Denon website and they have no documentation there for your receiver. But do not frown, I have some good suggestions for you. 0 Don't beat the dog. After all, it's their job to chew things. 1 Get a new, un-chewed cable and see what happens between the sub output and the sub woofer. If it works, your in business. If it does not work. Don't be discouraged . Go to step #2 2 If the sub output on the Denon has failed, and everything else is good. There is another way to use your sub. Install a patch system using the Headphone output from the front of the Denon. It may seem odd, but it works exceptionally well for the following reasons. It works on all signal sources. So if you are not playing a home theater source, you still have the use of your sub. You will need the following adapters. 1 A Male stereo phone jack to female mini-phone jack. (Something that would accept typical small headphone sets such as those on an iphone). 2 A stereo "Y" connector that that has a single stereo male mini-phone jack that has two "RCA" female jacks. 3 A simple RCA male to male stereo cable pair as is commonly used to connect CD players, etc. i.e. separate red and white RCA connectors at both ends. 1 and 2 above may be available as a single unit combined with each other. Take these adapters and connect the Item 1 into the Receiver, Item 2 plugged into Item 1, Item 3 plugged into Item 2 and finally the other end of Item 3 plugged into the two female RCA jacks mounted onto the back of the sub-woofer. If the sub only has one female RCA connector, get a RCA "Y" connector that has a single male end to 2 female ends. This setup will work perfectly with any sub. The reason is as follows. Most decent subs have an adjustable high frequency cut off. So you can vary it from about 20Hz up to about 140 Hz. I recommend that it is cut off at 80 hz. This way the bass transition is usually seamless between the woofer and the rest of the system. . Then adjust the woofer volume control in a similar manner. If it all works out, give the dog a treat and enjoy yourself. I really hope this helps, I love my sub woofer as well. Let me know how this turns out. If you have any questions please post them on the site and I'll get back to you ASAP. Best Regards, Mark
The
only thing you do is to open your receivers,then locate the output connector if
you see the female RCA jack ,then push it out the broken piece ,that's it
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver [email protected]
