Question about HP LaserJet P3005D Monochrome Laser 35 ppm Mono Parallel USB PC Mac Card Printer
49.4C02 Error Getting a 49.4C02 Error on the HP LaserJet P3005.
Posted by dwhite478 on
Russ Blakeman
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 87 Answers
The P3005 is known to have problems with a chip on the formatter, gives various errors to include the 49.2d9d, blank display and others. HP has not issued a recall or service advisory but is fully aware of failure of the chip on the formatter. Repair for this is to print a configuration page, replace the formatter board, bring the machine back up in service mode and put in the correct serial, service code and page counts into the new formatter's nvram memory.
Liberty Parts Team at lbrty.com has refurbished formatters at reasonable pricing with no return core to worry about. The PIN needed to access the service mode is 10300506.
Other problems with the P3005 are grinding in the fuser area, correctable by removal of the fuser, replacement of the 4 accessable gears in the side (left as you look into the back) and the main gear on the fuser then put the fuser back in and should be good.
Service manual available for free at feedroller.com - down the left navigation bar near the bottom is an icon and link to service manuals in PDF. No need to make someone on ebay rich selling copyrighted pdfs.
Posted on Jun 25, 2010
4 Related Answers
Anonymous
  • 32 Answers
SOURCE: 49 4C02 error
Well I was having the same problem. I cleaned out the queue by canceling the job that it was having the problem with. Turns out the data being sent to the printer was corrupt in this case.
Posted on May 30, 2008
Anonymous
  • 154 Answers
SOURCE: Hp CM8060 error code 49
This error is typically due to some sort of data corruption. If this is happening on a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Posted on Mar 05, 2009
Anonymous
  • 21 Answers
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Posted on Jan 07, 2010
HansPP
Hans Pearson
  • 2510 Answers
SOURCE: 49, 4c02 error in hp
This is what the result for that error code is:-
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter.
Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Posted on Feb 08, 2011
57.0 error on Hp LaserJet P3005
According to the service manual this is a sub cooling fan error. This fan is on the left side of the printer. 25365811-vovdf0wduqj1a05k1fbz2dih-2-1.jpg
Jan 12, 2015 | HP LaserJet P3005n Printer
What does this mean on my HP LaserJet P3005dn Printer, error 49.c02
This error is usually caused by out of date firmware. The printer is getting commands from a program like Acrobat it does not understand. Click thi slink to go to support page for your printer. Drivers Software Firmware for HP LaserJet P3005 Printer series Download the current firmware, I suggest the easy firmware update which is the first option, and then run that file.
May 20, 2014 | HP LaserJet P3005dn Printer
Hp laserjet p3005 freezing at times ,at times erroe49.4c02 pops
Hello, 49 errors can indicate a hardware or application error.
The formatters in the P3005 series have been plauged with problems, freezing being one of them.
For more on 49 errors follow the posted link.
Support 49 Errors CLICKHERE
Feb 03, 2011 | HP LaserJet P3005n Printer
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
HP p3005 printer cartridge error but cartridge is ok...how to solw this error..
The cartridge is not ok. Just because you replaced it doesnt mean its a god cartridge. You installed a bad cartridge so replace it and get your money back for the old one. P3005 printers are very intelligent!
Jul 15, 2009 | HP LaserJet P3005 Printer
Error message 52.00
HP LaserJet P3005 Printer- just changed toner and now service error displayed, tried to power on/off still not working??
May 14, 2009 | HP LaserJet P3005 Printer
Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Nov 27, 2008 | HP LaserJet P3005 Printer
HP LaserJet P3005D  Monochrome Laser  35 ppm Mono  Parallel USB  PC Mac Card Printer Logo
1,792 people viewed this question
Ekse
efs_perpends
efs_perpends
