Question about Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
My Sony Bravia 46" has a 1" thick black line horizontally thru the middle of the screen. It separates the top and bottom. Has anyone seen this happen before?
  • Anonymous Jun 17, 2010
    What's an LCD Controller?
    Last question, so if the LCD "screen" isn't damaged, could the LCD Controller be bad causing this Black line? Or can that not be possible?
Anonymous
  • 10,594 Answers
It sounds lcd screen problem and lcd panel (screen) will be replaced. Please check with local tv repair shop or nearest Sony service center for lcd screen replacement.
Posted on Jun 17, 2010
Testimonial: "Thanks for the quick response. That sure gives me an area where to look and fix it."
    LCD Controller is circuit board that is mounted on top center of lcd panel if you look its rear, it would be covered by metal shield.
    It is possible that lcd controller (T-Con board) is main cause of that black line and can be checked by swapping that board.
    In Sony part policy, lcd controller board is included in lcd panel.
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Sony tv problems
xbr 65x 850b sony ultra 4k tv smart ... what cause it to be black screen but you can hear the show playing
Sony HX750 has green line running vertically all the way down left hand side and black line running horizontally across top of screen
The fault is with its main power regulator section circuit itself. Check all the electrolytic capacitors there. Replace them. Replace the main filter capacitor too.
Line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
7helpful
4answers
A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Failing lcd(s) in middle of screen from top to bottom
Most likely the panel is bad. You have a year warranty on the panel. Please check your purchase date and contact a local Sony authorized repair facility.
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Open Questions:
See all Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV Questions
Sony BRAVIA  KDL-40XBR3 40 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
