Question about NorStar T7208 Corded Phone
Locked out of voice mail and system administrator cannot get in either
Posted by joegavw on
george peters
    President:
  • NorStar Master
  • 860 Answers
To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
To reset your voice mail password, press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
Posted on Jun 17, 2010
How to record ogm
Recording your outgoing message, or "greeting" as it is sometimes referred to, is a function that is dependent on the type of voice mail system you have. In any event you will need the password that's associated with that extension as well as knowledge of the voice mail pilot number (the main voice mail number). Actual instructions will vary widely as no two voice mail systems are the same. Contact your phone system administrator for assistance.
Jun 10, 2014 | Mitel Superset 4001 Corded Phone...
I can't log into my Nortel vm account
Change the administrator password by pressing Feature 985 dial 9 even though it is not listed as an option. The display will show Pswd: dial 73738767793. The display will show Reset pswd? Press YES. Now you can log into the voice mail system administrator using Feature 983 and the password 1020000 if you have 3 digit extension numbers. Add or delete the 0 between the 1 & 2 depending if you have 2 digit or 4 digit extension numbers.
Sep 17, 2012 | Nortel Networks T7316E Telephone Platinum...
How do change the outgoing "Night Mode" message in the Voice Mail System on NEC Electra Elite DTU 32D-1?
If you are using an Active Voice product (typical w/ NEC) you need to change the hours of operation on the voice mail system. "Night Mode" only changes the ringing characteristics of the phone system and where calls ring, not the greetings that play on the voice mail. The voice mail plays a particular greeting (Day/Night/Holiday) based on the time of day specified in the schedule. The system administrator for the voice mail would have to make this change.
Jan 24, 2012 | NEC Electra Elite 32D-1 Corded Phone
I'm the system administrator and I need to reset an employee/user voice mail password so they can access their voice mail
Use the admin password for mailbox 999 and choose option 4. It lets you reset any voice mail password.
Carl
Aug 25, 2011 | Panasonic KXDT343 Phone
Are there both a night menue and a day menue for partner pc mail
On the smaller flash card type voice mails no. On the larger voice mails yes.The option would be under auto attendants (3) in the system administrators mailbox.
Sep 22, 2009 | Avaya AT&T Partner Phone
I have a partner 18 phone and can't remember the password to my voicemail, what can I do?
Log into the voice mail as system administrator and reset it.
The administrator's procedure would depend on which voice mail system you have, but it should start with 770 99 xxxx.
Carl
Sep 10, 2008 | Lucent Lands Phones
Partner 18D System - Voicemail
Your telephone can be used on different Avaya phone systems and you can have different voice mail systems. They all program differently.
Someone should have administrative rights to the voice mail. They can delete voice mail boxes and create new ones or maybe just change the password. If you do not have a phone system administrator, you would need to determine what voice mail system and what phone system you have. All the manuals are available at www.avaya.com
Most likely you have a Partner ACS system but there are different versions. You could also use these phones on a Magix system and other Partner systems.
Nov 12, 2007 | Lucent PARTNER18 Corded Phone
Message Greeting
The KX-T7456 is a proprietary system phone. You have a Panasonic phone system and a voice mail, both separate items with their own part number. Your phone can work on several different systems and use different voice mail so your first step is to determine the part numbers from the system and voice mail. Then you will need a "programming" manual or possibly "administrator's manual" NOT a "user guide" for at least your voice mail and maybe for the system as well.
Oct 16, 2007 | Panasonic KX-T7456 Corded Phone
NorStar T7208 Corded Phone Logo
666 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
