Proscan 37LC30S60 TV Logo
Posted on Jun 17, 2010
Hi- I bought a used 37LC model (less than 1 yr old) without a manual. I cannot get any over the air local stations to come up under the TV mode. Does this model have a normal tuner ? The display shows "cable" and I can input a channel but there is "no signal".
Anonymous
Level 1:
  • Contributor 26 Answers
  • Posted on Jun 17, 2010
Anonymous
Contributor
Level 1:
Answers
26
Questions
0
Helped
4383
Points
71
If the display says cable, it won't get over the air signal. switch the source to antenna, hook up an antenna and go through auto program sequence.
Element tv troubleshooting no sound or picture gray screen
If its under a yr old return it as its in warranty
2answers
Remote control not working
Maybe have to program the remote for your specific model if the controller they sent you is a generic one. Google remote codes and your make model.Try newer batteries and make sure they're the right way round. Sorry for being patronising but you know what people are like. Never sure who's asking.
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Goodman A/C unit
look in your local yellow pages under air conditioner distributors for a local goodman distributor. A local company installed it but they all buy from a area distributor. call them with the previouse owners name and they may be nice and give you the name of the guy who installed your unit it is under warranty. be persistant good luck
2answers
Kenmore elite dishwasher, less than 1 yr old. Wont drain. I have pressed ''Drain'' on the keypad, motor/pump runs but no drainage. If blocked, where? Can I clear it without having to dismantle and remove...
take a shop vac and attach it to the ond of the drain hose to remove the water and if you are checking the drain pump then it has to be pulled out from under the cabinet.
if the unit is less than a year old just set it up for service it will not cost you anything
Apr 10, 2010 • Dishwashers
1helpful
Manual destoyed by 5 yr old
Hi, this is Phillip Prado from Mexico,I'm 9 yrs old,
actually I had trouble getting on line but
when my dad goes to the United Statse he finds all about my nintendoWii at this stores called 'GameStop' they have great stuff and very low prices on everything, probably you will find manuals there easily for less than ten bucks.
West Bend Model 41125 Suddenly Stopped under load
If the mixer does not work under load, then check motor , bearing , and control board.
If the mixer is less than one year old call manufacturer at the number listed on the owners manual.
To get parts for your mixer you can contact West Bend Appliance Parts - Bettervac 1-800-675-9491
Uniden UBC92XLT Scanner
UBC92 IN UROPEAN VERSION DOES NOT HAVE CLOSE CALL FEATURE LIKE BC92XLT
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
