Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Error C-2202 When we power on km bizhub 500 then c-2202 error comes
Posted by anish_colorc on
katambani
Help me clear the system error C2202 on my kyocera KM-C2630D. multifunction copier
Posted on Aug 18, 2011
Anonymous
    New Friend:
Check the charging unit and transfer unit, or because they are spark.
Posted on Jul 06, 2010
Aamir Hussain
    New Friend:
Solution ID TAUS0703124EN* Solution Usage 1
Description
Why is the image rotated 180 degrees when copies that are not stapled exit the machine?
Solution
CAUSE: Firmware update required.
SOLUTION: Switch 25-6has been made available to address this issuewith the release of version 30 firmware. Please update the machine firmware to
version 30 or above and set Switch 25-6 to1 (ON).Please follow these steps to set Switch 25-6:
1. Enter Service Mode.
2. Select System 2.
3. Select DipSW Setting.
4. Enter 25 under SW No.
5. Enter 6 under BIT No.
6. Select 1 (ON).
7. Select SET.
8. Select OK.
9. Exit Service Mode.
Note : The latest version firmware or system software is available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support
(CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware
Posted on Oct 07, 2013
taminol
    Sniper:
  • 62 Answers
C-2202 on a KM Bizhub 500 indicates a drum rotation problem. The best thing to do is open the machine up and look for a paper jam or something. Then try turning it off/on at the main power switch for 10 seconds (switch inside the front door)
Other than that, if the code comes back you'll need to call someone out.
Regards
m-press.biz
Posted on Jun 22, 2010
How can i resolve the error code of E002-0000 on IR 2202? when i switch on it mark that error and refuse to operate please help us
HOW CAN FIX ERROR E002 0000 ON CANON 2202 COPIER
It states:
Maros Klamar
  • 25 Answers
It signals problem in fixing assay, you should definitely first try to reset the error before continuing with repairing process ( * >> 2+8 >> * >> Function >> Clear >> ERR >> Ok), if after restart error comes again, look out for bits of paper and if there are non try to replace fixing film.
Feb 21, 2018 | The Office Equipment & Supplies
What this code sc21-01 machine Konica Minolta 920
SC-21-01 in KM bizhub-920 comes when auto cleaner get stuck in between at the Drum Charging Corona Unit.
Check if any obstacle in the movement of Charge Cleaning Pad.
Home position sensor is not sensing this pad at home position.
When machine turned on, Auto cleaning process runs, so if delay in movement, machine gives this error code.
Dec 12, 2016 | Konica Minolta Office Equipment & Supplies
J1601 error code in 6501 printer
check tray 4 rollers sensors and paper.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 04, 2016 | Konica Minolta bizhub Office Equipment &...
How to clear the error
MFP Board
Memory Board/1
Memory Board/2
EIF Board IC-414
Dual Scan Image Board
One of the boards is bad. Recommended that you have a qualified Tech look at the machine. Also might need to have the firmware upgraded. via Secure KMBS web site you can not get. The code is a abort code!
One of the followinf
Oct 22, 2015 | Konica Minolta Bizhub C224 Color Copier /...
Error code C-2703 Bizhub 500
bersihkan rumah korona bawah, dan ganti kawatnya
Aug 02, 2015 | Konica Minolta Bizhub 500...
Konica error code sc23-06
no such code for that model
Bizhub 500 codes are c-xxxx
Jul 06, 2014 | Konica Minolta Bizhub 500...
Error C-D36F apear in my minolta c250
NVRAM problems better calll KM tech because this kind of error codes need specialez tech and procedure like NVRAM data recovery etc
Feb 28, 2014 | Konica Minolta bizhub C250 All-In-One...
13f5 code error minolta 500
No such number code for a Bizhub 500
Feb 08, 2014 | Konica Minolta bizhub C250 All-In-One...
Minolta bizhub 501 error code c3502
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch. (inside the machine leave the the power on switch on on the control panel)
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jan 28, 2014 | Konica Minolta Bizhub 500...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,450 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
