Question about Xerox DocuMate 510 Document Scanner
I went from gateway to macbook pro and would like software to be able to use the documate 510 please
Posted by wvarnes753 on
hamster47
  • 739 Answers
Have a look here
Xerox DocuMate 510
Posted on Jun 17, 2010
Scanner Helper
    Scholar:
    New Friend:
  • 34 Answers
Hello.
I am a Support Engineer with Xerox Scanners.
The software that comes with DocuMate 510 is only for PCs. As you may know, many Mac users run Windows inside their Mac OS using various different brands of software to achieve compatibility with various different PC only software packages. If you search the internet for "Run Windows on Mac" you will find lots of options available.
We also offer 2 scanners that have Mac compatible software included. The Xerox DocuMate 3220 and the Xerox DocuMate 3115 can both scan directly to PDF files without having to install Windows on your Mac. The Xerox Mobile Scanner is a driverless scanner that can scan to a USB flash drive, SD card, or the Wi-Fi enabled Eye-Fi SD card.
If you continue to experience trouble or have any questions, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Posted on Sep 28, 2012
Xerox documate 510 locking up on windows 7
Hello.
I am a Support Engineer with Xerox Scanners. It sounds like others have given you great advice to address paper jams or locking up that you may be experiencing. If the "locking up" that you are experiencing is coming from the software, I would recommend updating to the latest available driver. I have written an article on the process that may be of use to you.
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Sep 27, 2012 | Xerox DocuMate 510 Document Scanner
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
I got a new hard drive. Now I can't find the software for me Xerox DocuMate 510. How do I get it onto my new computer?
Hi, below is a link to the Xerox site where you can download the drivers needed. Just click on the link (or copy and paste it into your browser address window), and download the drivers for your operating system. If this helps, please rate this answer. Thanks! Hal
http://www.xeroxscanners.com/en/us/products/DM510/drivers.asp
Jun 21, 2009 | Xerox DocuMate 510 Document Scanner
Issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
No paper message for ADF
I called Xerox and the technician told me the ADF cable was loose. I went home readjusted the ADF cable and now it works like a champ.
Jan 19, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox DocuMate 510 Document Scanner Logo
438 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
