I assume you mean the white wire under the rear motor cover? If so Sta-Rite puts a wiring diagram inside this back cover. Hopefully it is still intact for you. Depending on your model and if it is wired for 115vac or 220vac will make a difference. I would suggest you go to the link I attached and look up your manual. The manual will have the wiring diagram for you.
http://www.starite.com/
I hope this helps you out. Please rate my response. thanks
Thank you for posting your question here on Fixya.com.
I take it your cord is 3-wire plus a ground hence the 4 colors? If so you will only need to use white black and green. On the plug you should see a silver colored screw and a copper one; black to the copper and white to the silver. Green to the green screw and the plug is done.
Connect the white and black wires to the motor L1 and L2 terminals. It does not matter which color wire goes to which line terminal as long as only one wire is on each line terminal.
Ground the green to the green post in the motor and be certain you set the motor to 115 if it is a dual voltage unit that can be switched to either incoming line voltage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
