Question about Lutron ELECTRONICS MAW-600H-LA SMART DIMMER
Our dimmer switched worked perfectly last night and this morning. This afternoon when I went to turn the light on it didn't work. It works if you manually hit the up or down button on the side. However, the large dimmer button in the middle isn't working. It feels loose like it isn't attache or hitting the right place to turn the lights on. We have these installed all over our house and this is the first one that has ever done this.
Posted by kwik517 on
  • Anonymous Jul 07, 2010
    How old are the dimmers? Lutron had some issues with the "touch pad" plastic supplier back in the late 90's. I worked for an electrical distribution company selling them and we replaced quite a few (at Lutron's expense). Take a look at the bottom of the touch pad, there is a FASS (Front Accessible Safety Switch) that sometimes can inadvertantly get turned off or on. The older models have one that slides, the newer version has one that pulls out... however, since you said that the 'raise / lower' works on the side so this would indicate that the touchpad is defective. (the FASS switch completely removes power from the dimmer). The other 'symptoms' to look for: - Are the LED's on the side are on or dimmly lit. If they are not and you are able to manually control the light as you are now, you should call Lutron's tech support line. - Have you recently changed the 'type' of lamp in the fixture that the dimmer controls? (incandescent bulb to CFL for example). Let me know if I can help! (Lutron Tech Support number: 800-523-9466 - 24/7)
Hippy_dd
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • Lutron Expert
  • 112 Answers
Sounds like an internal part has broke and you will have to replace the whole switch. anytime you have trouble with something like that it is always best just to go ahead and change it. it doesn't if its a day old or 10yrs old. not worth the chance of burning yourself down.
be glad to help you further if you need it txt me at 865-888-1220
Posted on Jul 06, 2017
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: Dimmer switch is not dimming
florecent bulbs wont dim unless they are dimmable.
Posted on Dec 25, 2008
Anonymous
  • 1605 Answers
SOURCE: 3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Posted on Mar 30, 2009
Anonymous
  • 44 Answers
SOURCE: A fixture on a Lutron Maestro dimmer switch stopped working.
This dimmer was not made to dim a load smaller than 40VA. That halogen bulb would only have been 20VA or so.
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
I think that when your bulb burnt out, the dimmer over-volted the transformer and smoked it. That said, I think you have a fixture problem and, possibly, a switch problem, too.
Posted on May 30, 2009
Anonymous
  • 323 Answers
SOURCE: Lutron Maestro dimmer rocker stopped working
Because the switches are relatively inexpensive, there aren't kits to repair them when they fail mechanically. Your best bet is to get an exact replacement from a Home Depot or such, turn off the breaker switch, and rewire it exactly as it was, using wire nuts and tape.
Posted on Oct 31, 2009
Anonymous
SOURCE: My Lutron dimmer/lights suddenly will not turn on.
Indicator light is OFF.
Either dimmer stopped working or power to dimmer is off.
Check if electricity is present inside box.
Check nearby electrical plug to see if everything nearby has power.
Swap dimmer with regular switch and see if lights turn ON.
Check dimmer wires: if wires to dimmer are pushed into 'quick connect' holes on back of dimmer, these wires can get loose.
If dimmer is connected by wire nut, sometimes a wire can pull loose.
If no electricity is inside the box, and breaker is ON, then there is a loose wire inside one of the boxes on that circuit and electrician has to track back until loose wire is discovered.
Replacement parts for in-wall devices are not made.
If new dimmer is necessary, consider lighting factors:
Total wattage of lights. New dimmer has watt rating.
Type of lights. Dimmers specify florescent or tungsten (incandescent) or both.
Single-pole and 3-way. If two dimmers control same lights, one is control dimmer, other is companion dimmer.
Posted on Nov 16, 2010
Why are Dashboard lights not working on high beam?
check the dimmer switch, I had the same problem. this dimmer switch didn`t dim on low beem but went out on high beams, turned the dimmer switch up and down/on and off and it came back on.
Apr 24, 2014 | 2008 Toyota RAV4
Parking lights, tail lights, and dash lights dont work
i assume you have checked all lighting fuses. if you have not, start there. do you have brake lights? if you do have brake and head lights then i would suspect the dimmer/light switch.
Mar 31, 2014 | 2001 Dodge Ram 1500 Truck 2WD
Computer
Well you've lost power to one or two major circuits. Could be a problem with the key switch or a major fuse in the engine compartment.
I would check the fuses for power and find out which ones are dead then go from there.
Jul 23, 2013 | 2000 Chevrolet Malibu
We have changed the dimmer switch, but when I have to change my lights from dim to bright my lights go out. This was happening before we changed the dimmer switch, but was not as bad. Last night when I had...
I had a similar problem with my Camry that the light will go out when I go from dim to bright. I found that in the dimmer switch contacts there is a small plastic piece that runs through one or two contact to operate a set of contact. Mine was broken. Seeing that you have a new switch it could be that yours are maybe not correctly in place - that is if it works the same as a Camry's.
Jan 31, 2012 | 2006 Dodge Grand Caravan
No lights
Check headlight and high beam switch for power in, power out. If power there, change whichever switch isn't working (remember dimmer switch gets power from headlamp switch) If no power going to headlamp switch check main fuses and fusable links for problems.
Feb 21, 2009 | 2002 Chevrolet Impala
My cars headlights no longer come on
First Rule Out Fuse And BULBS it took 20 years but I did see BOTH Blow out Same time .
If all is Well there and you Knoe how to test dimmer switch do so and Obviously if dimmer is good Headlight Switch is Bad
Jan 21, 2009 | 2001 Toyota Corolla
LED screen not working
Could be the tube[backlight] has blown. Can you see any image on the screen if you angle it around to the light? Check the Manufacturers Web site- tech support If it is a young camera they may offer a refurb on in exchange if you are out of warranty
May 12, 2007 | Canon PowerShot A75 Digital Camera
Lutron  ELECTRONICS MAW-600H-LA SMART DIMMER Logo
307 people viewed this question
Top Lutron Electrical Supplies Experts
jdthefixer
mpservices
Nick
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
