It sounds like a cooling fan problem. You state the temp runs high when at a stop and idling, but goes down once you start moving. If the fan(s) are not operating, moving forces air through radiator keeping the temp at a normal range. Have the relay/fuse for the cooling fan(s) checked. They are located under the hood in the main fuse/relay box. If they are good, check the sensor that sends the signal to the fan(s). If it is good, then it could be a bad motor on the fan(s).
For car running hot and overheating issues, I suggest to you go
through this help links. Click this link below and go through the
troubleshooting procedure to take care of the problems: ----
temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Temperature gauge keeps fluctuating up and
down close to red?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and
troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Temperature gauge does not move and no heat
when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
This details will help.Thanks.
troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
troubleshooting?
----------This details will help.Thanks.
