Question about Kenmore Elite Oasis 27052 Top Load Washer
Hello, I have a Kenmore Elite Oasis washer model
Hello, I have a Kenmore Elite Oasis washer model 27087603. When I start the cycle, the water runs, then beeping with a dL code. I think it is the door locking mechanism because I do not hear it click to lock. I unplugged it over night, the next morning it worked. It stoped again with the same code dL later that afternoon. It is only 2 years old, and I love it when it works, but am not a happy camper when it doesn't. Any help would be greatly appreciated, thanks!
Posted by mlalsup on
blueextc3221
  • 15,935 Answers
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Posted on Sep 15, 2010
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Where can I get a service manual for a kenmore elite oasis HE mod. 110-27087603 clothes washer?
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Apr 04, 2011 | Washing Machines
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis top load model 580 error F51
There is no reason or condition that will requir having to doing that for correct operation. That indicates the board as being defective. Just asking if your water is draining correctly? When you start cycle, after it finnishes loading the water, can you get it to drain at all. If you can, the board is the problem.
Sep 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
Ok these are not the series 70, getting a model number off the door will reallllllly help. Some of these sound like the oasis. F1 is motor control or primary control failure and F 41 is a rps thermistor failure.
For the guest with the 11027086601 kenmore elite oasis here is a link for supplying me with a partial model number, much thank yous!! paste in a browser:)
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11027086601&productCategoryId=0153200&brandId=0583&modelName=RESIDENTIAL WASHER&diagramPageId=00002&componentDescription=CONTROL PANEL PARTS&documentId=K0601003&backToLink=Return to Sub Components list
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
Michael Thomas
Michael Thomas
Lawrence Oravetz
Vernon Taylor
