Question about Rowenta DE851 Iron
My iron smells bad and transfers the smell to clothing. I have had my iron for 10 years and love it, but my housekeeper left water in it.
Posted by prescott_pat on
  • Anonymous Apr 01, 2014
    Can hear the pump working, but water is not being transferred from the filling dock to the iron
Chester Sohoski
  • 264 Answers
Hey, You have a "Mildew" issue. Just like leaving clothes in the washer too long before putting them into the dryer. If you read your iron's manual, it is recommended to use "Distilled" water...not tap water. Tap water has impurities...Distilled water does not. Here's the fix...MAKE SURE YOU ARE HOME WHEN YOU DO THIS! Get distilled water (From Grocery Store) Mix 1/2 cup distilled water with 1/2 cup vinegar. Put this into your iron and leave it on. To help it along, push the "Steam" button frequently. You can do this several times...the acid in the vinegar will clean out the residue. Once this is done, fill the iron with water, add a couple of drops of lemon juice and you'll be good to go. I know this to be fact...just did it myself : )
Posted on Jun 16, 2010
Siegfried
    New Friend:
    Problem Solver:
  • 5 Answers
Yes, it is ALWAYS best to use distilled water in any iron, no matter what a specific manufacturer may, or may not, say. The reason is simple: There's nothing in distilled water to contaminate your iron, and as a result, you will not have stained clothes.
If your iron is already dirty from using tap water... clean with mixture of vinegar and water by pouring mixture into iron, bring to full temp for a few mins, flush through steam vents, and rinse with distilled water. You may need to invert your iron to purge the water from tank as well. Repeat as many times as needed until perfectly clean.
Once clean, NEVER use any other type of water in you iron. Period. Always use distilled water. Hope this helps...
Posted on Apr 12, 2014
Morphy Richards iron smells bad.
Do you use distilled water in your iron. The filters may have bacteria on them, especially if the filter does not get very hot. Bacteria thrives in dark, wet environments. The bacteria has moved away from the filter into the iron, so changing filters would not help much for very long. I would buy a new iron that does not use filters and only use distilled water in it. Distilled water stops mineral deposits from forming inside the iron.
Dec 05, 2015 | Morphy Richards Irons
How do I empty the Hand help steamer? Does the white plate come off or is it emptied from the hole the water is filled?
Most often, cleaning your clothes is as simple looking at them (or smelling them), and making a judgement call. However, it's not just about that obvious stuff, Brit Lab takes a look at all the gross stuff your body produces that you can't just use the smell test for.
Of course, everyone's laundry rules are a little different, but if you're just worried about bacteria build-up, it's best to wash anything that sits close.
Jan 15, 2015 | Conair Gs15 Handheld Clothes Steamer....
Does not heat up
Visual Check:
1. Do you smell burned electrical wire? If none,
2. Check the cord for damage, and the outlet for electricity ((plug in another device and see if it turns on)). If none,
3. Does the water reservoir or iron face have visible mineral deposits (i.e. need cleaning)?
Possible solutions:
1. On COLD, UNPLUGGED iron, clean working surface with non-abrasive cloth.
2. Try Vinegar & Water cleaning to remove mineral deposits (if warranty allows):
Mix equal parts water and white vinegar (abt. 1/3 cup each).
Pour into water reservoir.
Turn on the iron with steam option.
Allow to work, upright, for 2-3 minutes.
Turn all controls to low before unplugging.
Drain into sink ...carefully, it may be hot!
Flush with plain water.
Reheat iron and test on scrap cloth to clear any residue.
BE SAFE and work carefully. If iron still does not heat after thorough inspection and cleaning, the unit may need a qualified technician.
Dec 29, 2012 | Bosch Irons
Cloths steamer not working keeps saying its out of water but its not.
Suspect that your iron's steam holes are being blocked by calcified water (hard deposits)and need to be cleaned. Take one cup of white vinegar to one cup of water and pour it in the Iron. let it sit heating for about 30 minutes. Repeat if necessary. The acidic vinegar will disolve the calcium and unblock the vents. The final one after the vents are clear, 1 tbs of lemon juice to one cup of water gets rid of the vinegty smell.
Jan 10, 2011 | Irons
Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
Dec 17, 2009 | Irons
How do I clean a rowenta DX8800 iron that leaves deposits on my garments
Use a white vinegar and distilled water solution in the iron, but don't do any clothes with it. Let it soak for a while, then heat the iron and let it blow out any debris. Fill again with distilled water, shake well, and let it steam out. Do this again until there is no vinegar smell coming out. If you use only distilled water, you should have no further problems like this.
Sep 18, 2009 | Rowenta Professional DX8800 Iron
Sand is coming out of the vent holes
Probably not sand but crystalized minerals from tap water. Heat up the iron then unplug it and add white vinegar. Shake it up and pour it out of the fill hole. Repeat if necessary. Then rinse it out with distilled or filtered water. Before using on clothes, fill with water and steam iron an old towel to get the vinegar smell out. Use only filtered or distilled water to prevent this happening again.
Jul 19, 2009 | Irons
CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Dec 04, 2007 | Rowenta DX6700 Iron
Rowenta DE851 Iron Logo
8,467 people viewed this question
Top Rowenta Irons Experts
Paul Bade
Fahr Quad
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
