SOURCE: LG Bottom Freezer Freezes But Food Compartment Warm
Try completely defrosting the unit (turn it off), then start it again and see what you get. Check that the ventilation around the outside - especially the back - is ok. If no luck from that then you should be able to get it fixed under warranty; http://us.lge.com/general/contact.jsp If your warranty is not valid for any reason, please ask again and we may be able to help, however the majority of things that might need to be done to a unit like this are illegal to perform unless you are qualified, and require quite expensive special tools. It is almost certainly fixable, and would certainly be cheaper than a new fridge. Hope this helps :)
SOURCE: Food freezing in refrigerator.
I have a side by side GE Refrigerator only about 4 years old, the setting on the Refrigerator is set at 37 degrees but it continues to go to 20 degrees and freezing my vegtables. Help.
PS - i did vacumn the back filter a week ago with no help.
SOURCE: Kitchen Aid Fridge
no ice in freezer section??? not able to keep meat frozen , is it making ice??? sounds like a compressor issuew and not covered by manufacture warr is generally not a worthwhile repair
SOURCE: trouble shooting defrost system
you can not manually start a defrost cycle
go to the freezer and check the heater and bimetal they are in the evaperator coil if these parts check good then replace the adaptive defrost control
SOURCE: Kitchen Aid Fridge problem
ok first the freezer does all the cooling for the whole unit and in order for it to cool properly the freezer needs to be a certain temp it should be around -10 -6 if its not reaching that temp it will still freeze and apper to be working right also check to hear if the freezer fan is running as it pulls air from the fridge and cools it then blowes it back look in the freezer on the back wall toward the bottom see if frost is building also in the refridgerator section on the left hand side of the cabnit is a return vent make sure its not blocked and see what the thermostat in the freezer is and let me know we need to know things like this to help narrow the promblems and people dont reply to the questions so we cant answer appliance repair is a skill
upper right-hand corner of the fresh food
compartment, right below the temperature
controls.
The filter cartridge should be replaced
every
six months or earlier if the flow of
water to the water dispenser or icemaker
decreases.
Download User Manuals HERE
Sea Breeze
Older Model
TFX25ZRY
Use and Care Manual for above model(s)
TFX25ZRBAA
Series 25.2 Cu. Ft. Side-By-Side Refrigerator with Dispenser
Quick Specs
Energy Guide
TFX25ZRBWW
Quick Specs
Energy Guide
TFX25ZRBBB
Quick Specs
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
