RCA 25110RE3 Phone Logo
Question about RCA 25110RE3 Phone
I am constantly having problems with this phone's headset unit. The actual phone works, but the headset goes dead. I've changed the battery, and it still is dead. The red light is ON but it still isn't working. Any help would be much appreciated.
Anonymous
  • 126 Answers
Replace the headset
Posted on Jun 17, 2010
1helpful
Newly installed in a camper from the leisure battery,power to the unit and will load the cd then the unit goes dead.Press the eject button and the unit illuminates and ejects and again goes dead
Do you have power going to both the red and yellow wires? The red wire generally goes to a switched power source and the yellow should be constant. Both wires need to have power going to them in order for the unit to work properly.
My blue tooth - plantronics explorer 232 has a constant blue light. I can't get it to turn on or off. Please help.
Try letting the battery go completely dead on the headset and then recharge it. This should fix the problem.
Good luck from Headsets Direct!
Hi, we use the plantronics cs60 headset at my place of work and the earpiece stopped working so i have changed it for another one and i have paired them together but now when i pick the ear piece up the...
It would depend on what headset you actually purchased. You say CS60 but it may be the Plantronics CS50 or CS55 headset. The headsets are not interchangeable. If you are not sure what headset you have, simply look on the bottom of the base for the part number. On the headset you can read what part number that is by very carefully looking under the battery. Here is a link to open the battery.
Here is a link to the CS60 instructions to replace the battery.
I think that if the base and the headset are the same it might be that you may need to subscribe or pair it together again.
Here is a link to the CS60 subscription and pairing instructions.
2answers
There is a constant beebing in my ear every 3/4 seconds and sometimes my customer can here this too How can i stop this???
Usually, that's an indication that the battery is dying. You need to recharge it. If the headpiece is not holding a charge anymore, you need to replace the battery. Model of battery is CPP-512Q. If the unit is fairly new, you can try reseting the battery by taking off the cap on the headset and then unplug the battery and plug it back in. Good luck.
Jabra 2080 won't connect. Blue light flashes constantly.
I apologize you having trouble with your Jabra Blue tooth Headset.
The reason why its flashing is because it has not paired with a device or the battery may be low.
1. Take the battery out of the unit to fully reset the unit.
2. Put the battery back in the unit "turn the unit on"
3. Try using the code 0000 this is the default code to pair the headset with your hand set.
If the above steps does not work it might be because of a low battery, Thus I would recommend purchasing a new battery for it then try the steps above again.
Again we apologize your having issues with your headset, if you have any further questions please get back with me.
Thanks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4helpful
Whole house ringing when cordless phone is used
try deleting all headsets using primary headset (marked with no.1): 4-base/8-deregister/default pin '0000' and register them again using each headset (3-headset/8-register/same pin). it worked for me.
Battery
A fully charged battery should last up to 4 hours if it's being used A LOT! But I lost mine and it was in standby mode for pretty close to 3 days and when I found it I was still able to use for quite awhile before charging it again.. So yes, it sounds like it had a weak battery..
Hs820 light stays on
same problem with mine...
there is no solution for that, I've had the same problem a year ago... and it's a useless unit... there's no solution and there are a lot of Hs820 with this problem....
This headset is a piece of sh** !!
Top RCA Lands Phones Experts
Marvin
Marvin
Tom Chichester
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
