SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal
fault is the natural cause for protect mode. If all the above did not
work, then the problem is a blown component or an internal fault. In
this case the unit must be taken apart , tested and repaired by an
experienced person.
If the unit is less than one year old, or if you
want to get service, call Sony at the phone number listed on the
product documentation.
Regards.
SOURCE: I need to reset the region code on a samsung home
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray.
1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
2. Reconnect to mains
3. Turn on player with remote.
4. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2
6. Press ENTER on remote. (The tray will open and player will power off and close tray.)
7. Switch on power from remote.
8. Player is now Region Free.
Allows both region 1 & 2 DVD's to play.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: when i turn samsung HT-TZ212 home cinema system on
Hi , your amp board need to replace , get one from ebay.
