Question about Euro-Pro 473
How to sew thick material - Euro-Pro 473
Posted by anndominguez on
ken dourof
  • 980 Answers
Size 16 needle, don't put more layers under the presser foot than the height of the presser foot, see what your manual recommends
Posted on Jun 19, 2010
Sewing machine is out of sycn
If the needle/hook is out of time, you will probably need to take it for service. There are web sites and videos on the internet that show how to correct timing if you want to try it yourself.
Apr 26, 2016 | Sewing Machines
I sew thin leather w/Janome MC4000 using leather needle. Want to try thicker leather but not damage machine. How thick will this machine take?
Be careful sewing thick materials with a domestic machine. Even though a lot of machines are supposedly able to sew thick leather & fabrics, it could damage your machine in the long run. If you value your machine, you might want to find a second machine (used mechanicals, older Singers, etc., probably work better for this purpose) to sew thick fabric. Save your nice primary machine for more conventional uses.
Dec 13, 2015 | Sewing Machines
Where is the control for different material thicknesses
test sew on the different material to see if the thread tension has to be altered with the different thickness thread
Nov 29, 2015 | Sewing Machines
Sewing leather & thick material
Industrial, NOT domestic
Mar 06, 2014 | Sewing Machines
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
BOBBIN COVER PLATE CONTINUALLY FALLS OFF
the bobbin cover may need to be replaced, it would be a good idea
to have the machine checked to see why the cover does it with
thick fabric
Aug 20, 2012 | Janome Sewing Machines
Thread keeps breaking when sewing through thicker materials
When you sew any thick material on any machine the needle cannot form the loop properly as the needle comes up because the material is keep the tread tight to the needle, the only real way round it is to sew slowly.
Jun 23, 2010 | Consew 206RB
Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Oct 14, 2009 | Husqvarna Huskylock Computerized 905
Treading sewing machine
these are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Jun 23, 2009 | Brother XL-2600
Problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Mar 29, 2008 | Juki DDL-8700
Euro-Pro 473 Logo
Top Euro-Pro Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
