SkyScan 86709 Atomic Wall Clock Logo
Posted on Jun 16, 2010
What does TX in a battery symbol mean? - SkyScan 86709 Atomic Wall Clock
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5318
Points
13
For Models 88900/901 TX in a battery symbol is the Low battery indicator (Sensor)
RX in a battery symbol is Low battery indicator (atomic clock)
Source: Page 4 of the manual.
Will not tx or rx.
likely a bad battery. brand & model number would help a lot.
What does the lightning bolt inside the battery symbol mean on the screen of the digiland tablet dl700. It wont charge
That symbol means that the tablet battery is plugged in and is supposed to be receiving charging voltage. If the battery is bad, it may not charge but the tablet will still work with the charger plugged in.
1helpful
I don't know what the warning symbol means on my prius dashboard. I assume it means I need a new battery. Does anyone know?
Your owners manual should have the definition of the symbols.
The battery light usually means the alternator is not charging the engine battery, and the red symbol with the outline of a car next to it is a problem with the hybrid portion of the car.
I would strongly recommend you get it checked out by the dealer or someone experienced with hybrid cars.
What are electrical symbols TX, C, NC
In electronics, tx means transmit (transmission), c probably means
clear but not sure about nc
2helpful
G AND AN ARROW SYMBOL NEXT TO BATTERY SYMBOL, WHAT DOES IT MEAN
i have a +@ symbol showing up on the top left hand corner of my phone whats this mean and how do i get rid of it
2answers
I have two uniden GMR1088-2CK radios, If I press the transmit button on the side and speak into the Mike you can see tx appear in the display, the 2nd unit receives the call, rx appears in the display and...
What this code indicate mean that your radio have have been compress with power however the can also be an indication of lower power supply but most of the time is always power compress.
What you need to do to solve this code problem is to put off the radio for some time allow it relax, then remove the battery if possible after some time replace it if you are able to remove the battery then put on the radio and operate it.
Good luck.
1helpful
Palm tx wont turn on
When the battery is discharged, it is best to charge it overnite.
Have you reset the TX?
Hold the power button down and push in the reset button on the back of the TX with the stylus. Hold the power button down until you get the screen where it ask you if you want to erase/reset the unit. click yes to reset.
Then when it comes back up, re-sync it with the Palm Desktop on your computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2helpful
2answers
Flashing Battery Symbol on GPX PDL805
The appearance of a battery symbol while you are using just the battery means that you are using just the battery.
That's it.
No Problem.
The flashing battery symbol is a constant reminder to you that a power intensive function is only supported by the battery, and that you should make external power available so as to complete the task without losing power in a battery drain event.
11helpful
3answers
Flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
1helpful
FLASHING AMBER UNDER LIGHTNING SYMBOL
Is it an amber lightning bolt? (I am assuming thats what you mean by UNDER lightning symbol)
That is the charging symbol for your battery, it means your battery is being charged by your power adapter.
Top SkyScan Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a SkyScan Home Expert? Answer questions, earn points and help others
