Question about Jack Lalanne Power Juicer 250 Watts
Where the blade of the juicer screws on has broken off
Posted by ryan_harry66 on
Michael C. De Vito
    Genius:
  • 1,970 Answers
Mcdevito75, Refer to the owners manual for return of the juicer for repair, or go online to Jack Lalanne juicer for repair/return details.
Posted on Jun 20, 2010
  • Michael C. De Vito
    Michael C. De Vito Jul 21, 2010
    Mcdevito75 here, Thank you for your solution, while true, still contact Jack Lalanne online or phone, see what they can do as far as a replacement Juicer goes. This is an Old Number from his commercial on TV maybe 2 months old, 800-695-9247
rboydsmith
    New Friend:
  • 7 Answers
It's junk and cannot be fixed.
Posted on Jul 21, 2010
BRAKET ON JUICER WHICH HOLDS BASKET FROM MOVING IS BROKEN CAN IT BE REPALCED OVER 15 YEAR OF USE OF JUICER NOT BASKET IS MOVING DUE TO BROKEN HOLDING BRAKETS JUICER IS INWORKING CONDITION AND FINE I...
Are you talking about the clutch nut that screws
down on the basket and blade, or the small clips
that the cover rotates and snaps into. Either way
call Waring at 1 800 492 7464, they should have
the part.
Oct 16, 2010 | Acme 6001 Juice Extractor
The screw peg and blade of mya Jack LaLanne's Power Juicer are broken. They can replacement?
they have customer care- web search- jack lalanne juicer ,click on customer care under official site
Oct 08, 2010 | Jack Lalanne Power Juicer (Stainless...
Broken plastic screw from motor shaft
According to Jack Lallanes Support you need to buy a new motor! No replacement part for that specific part!
I have the same problem and also do not want to buy a new motor! Scam!
Dennis
Nov 21, 2009 | Jack Lalanne Power Juicer 250 Watts
The plastic screw, which the grater is screwed onto (looks like part of the motor) is broken.
I had the juicer for exactly two weeks and the same piece broke. The little plastic part in which the blade screws onto. Called the company and they were actually no help at all. Please don't waste your money!
Nov 14, 2009 | Jack Lalanne Power Juicer 250 Watts
No crescent tool included with purchase to remove the blade
Make sure the Juicer is unpluged. What you need is the cresent tool or two metal objects to place in the two holes opposite each other and press down the metal objects in the holes while turning counter clockwise. It kind of acts like a lock and key system.
Jul 28, 2009 | Jack Lalanne Power Juicer 250 Watts
The pusher to push the food into the blade is coming into contact
The blade maybe was not screwed in right. Screw out the blade using the blade tool and screw it back again making sure it is screwed in and fitted in right. Do not tighten too much. It breaks easily.
Jul 10, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack La Lanne's Juicer
I removed mine by removeing the 3 screws on the blade
and lifting the whole filter out.
Feb 22, 2008 | Jack Lalanne Power Juicer 250 Watts
How to dissassemble Jack Lalanne Power Juicer?
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
Jan 01, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
306 people viewed this question
Top Jack Lalanne Juicers Experts
Roger Paull III
Andrew Taylor
Andrew Taylor
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
