Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Electrolux Caravan Fridge RM4271
I have an Electrolux Caravan Fridge/freezer RM 4271. I want to fit a new Mains Electric Thermostat Switch which has a temperature sensor similar to a thermo coupling. There is a similar coupling for the 12 volt system on this fridge and both are channelled thro a small hole at the top rear left hand side of the fridge body. I need to take the old one out and put the new one in. It appears that both couplings or sensors are just pushed in and pulled out but before attempting this I would like to be sure.
Can you advise if I am right
Posted by Michael Greene on
5 Related Answers
Anonymous
SOURCE: Hi i have a 3
A simple remedy to the fridge working correctly.
I wasnt aware that the mains dial turned fully to an 'OFF' position. Once I had turned the dial until it 'clicked' off, I tried the gas and it lit and cooled perfectly.
Posted on May 29, 2008
Anonymous
SOURCE: we have caravan electrolux rm
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Posted on Jul 08, 2008
Kristian Slack
SOURCE: Our caravan fridge electrolux rm4206
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Posted on Feb 07, 2009
Anonymous
  • 269 Answers
SOURCE: Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
Posted on May 12, 2010
Anonymous
SOURCE: electrolux frost free fridge freezer
The evaporator drain can become blocked. Water backs up and eventually falls out into the freezer and freezes. If this happens you should see ice build up inside the freezer.
The evaporator heater can blow. This allows condensation to freeze and not drain away. I have tried replacing it but I cannot confirm that I have solved the problem.
Another problem is liquid water draining onto the fan in the freezer compartment near the evaporator. If this happens when the fan is idle (presumably when the fridge and freezer are both down to the right temperature, water falling on the fan blades will freeze. The motor is low power and it may not have enough torque (turning power) to overcome the imbalance. This stops the cold air from circulating to the freezer and fridge. The control circuit may detect the fan is not turning or the temperature may rise setting off the alarm.
I have an Electrolux ER3162BN fridge freezer.
Posted on Jun 26, 2010
Why is the pilot light on my ERN7926 frost free flashing?
To Start the Appliance
Allow the appliance to stand for 2 hours after
installation. Plug in the appliance and switch on at the mains
supply. Turn the thermostat control (B) to a midway
setting and adjust the slider control, situated on the
back wall of the fridge section, to a midway position
between "MIN" and "MAX".
The pilot light (A) will illuminate. Leave the appliance for approximately 4 hours for the correct temperature to be reached before placing food inside.
To switch off the appliance turn the thermostat
control to position "?"
After 4 hours, measure the temperature in the refrigerator and freezer. Should be between 2 and 10 degrees centigrade in refrigerator and app. -18 in freezer.
Dado
Sep 07, 2014 | Electrolux Freezers
Electrolux evf 10240 do not heating. Everything else is OK. New heater is in machine. What is the problem?
Over temperature safety thermostat maybe open circuit if fitted temperature control thermostat or thermistor faulty ,water level sensor tube blocked so circuit does not switch on without water level correct. Lastly broken wire somewhere
Apr 12, 2014 | Washing Machines
Temperature sensors
I have an E402 fridge (403 litre model with freezer on bottom) . I just dismantled the freezer back wall due to a bad defroster element and noticed that on the back wall of the freezer is a small raised "cavity" or "slot" that the black thermostat fits into nicely. In my fridge, it is above the Collins coil and a bit to the right of centre(closer to the wire entry hole). Hope this helps
Feb 15, 2014 | Fisher and Paykel Active Smart E522B...
Fan oven is getting much hotter than what the thermostat indicates. Is it the thermostat or the switch
The thermostat controls the oven temp, therefore it is logical to assume that the thermostat is not sensing the temperature properly, so I would fit a new one.
Nov 27, 2010 | Electrolux EOD5310 Electric Double Oven
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
Our caravan fridge electrolux rm4206 gets cold on both gas and 240v mains but does not seem cold enough ie freezer compartment is not quite frozen and fridge compartment is not cold enough. Any...
Aug 27, 2008 | Electrolux Refrigerators
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Jul 05, 2008 | Electrolux Refrigerators
Fridge not working
Fridge is not working then don't worry we will be here to help you.Just dial Dialfix.in number. Refrigerator Repair Services in Hyderabad DialFix
Aug 13, 2007 | Electrolux ER7926B Bottom Freezer...
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
571 people viewed this question
Top Electrolux Dishwashers Experts
Mike
tglynn
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
