Question about Red Hat Enterprise Linux ES Basic Edition
I want to access internet using redhat os i do hv inet connection in windows how can i configure ???????
prathap29
    New Friend:
I have a windows 7 os and net connection, Now I have Installed Redhat Linux, Im new to linux, I want to use internet on linux. help me, when i try to acces net it displaying server not found
Posted on Jun 17, 2011
Anonymous
    Guru:
  • 214 Answers
Default your internet settings
Posted on Jun 16, 2010
INET light is on not able to connect to internet
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Oct 18, 2013 | D-Link 802.11g Wireless Router WBR-1310...
Tip
How to Setup Linux Mail Server
<p><span>Email is an important part of any Web site that you create. In a home environment, a free web based email service may be sufficient, but if you are running a business, then a dedicated mail server will be required. <span>A mail server is an application that receives incoming e-mail from local users (people within the same</span><span> </span><span><span>domain)</span> and remote senders and forwards outgoing e-mail for delivery, as example Microsoft</span><span> </span><span><span>Exchange</span>, Gmail,</span><span> </span><span><span>etc.</span></span></span><span> <span> </span></span><span><span>The system uses</span></span><span><span> </span></span><span><span>SMTP </span></span><span><span>(Simple Mail Transfer Protocol) or <span>ESMTP </span>(extended SMTP) for sending e-mail, and either</span></span><span><span> </span></span><span><span>POP3</span></span><span><span> </span></span><span><span>(Post Office Protocol 3) or <span>IMAP</span></span></span><span><span> </span></span><span><span>(Internet Message Access Protocol) for receiving e-mail</span></span><span><span>. </span></span><span><span>In windows forum</span></span><span><span> most of workstations are use Microsoft Exchange server or outlook express. In Linux forum there have also an easiest option to send and receive mail. In Linux configuration of mail server is easy flexible too.</span></span><span></SPAN><br> <p><span><span> </SPAN>In most of Linux workstation RedHat Linux are used for their Server. In RedHat Linux we use sendmail to create a mail server that will relay your mail to a remote user's mailbox or incoming mail to a local mail box. On our RedHat we will find sendmail's configuration file as /etc/sendmail.cf. If you download and compile sendmail you would find it in /etc/mail/sendmail.cf. To configure sendmail you have basically 2 options. Either you edit the sendmail.cf file directly or you create the sendmail.cf from an m4 file such as sendmail.mc. Here to explain the process I will list the steps to produce a custom sendmail.mc file.</SPAN><br> <p><span></SPAN> <br> <p><span><span><b>SendMail Configuration:</b></SPAN></SPAN><span> </SPAN><span><span> </SPAN>In Redhat Linux dovecot and sendmail packages are used as service demon for Mail server. At first I install the available sendmail RPM package by YUM and also the dovecot RPM. After installation first I have edit the sendmail .mc file. After installation of sendmail package it locates as sendmail.mc in /etc/mail. In the sendmail.mc file I have find the line DAEMON_OPTION and edit it with # before the line to uncheck it. Then I find Local Domain and edit it also with the system FQDN. After editing save the sendmail.mc file. After exiting from sendmail.mc I moved this .mc file to sendmail.cf with m4. Here the SendMail configuration is complete. Then I go to the /etc/dovecot.conf file and edit it. I just find the protocol line and uncheck this line. After that I save this .conf file. After all configurations I have start the service demons with chkconfig command and restart the both services. And the mail server was going on swiftly.</SPAN><br> <p><span><span> </SPAN>So it is very easiest job to configure a mail server in RedHat Linux enterprise server.</SPAN>
on Mar 21, 2011 | Computers & Internet
Tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
Globe access point
APN: Go to MENU, SERVICES, DATA ACCOUNTS, GPRS, create NEW SETTINGS.1. if your globe sim card is not yet activated for inet, then configure it manually.. go to connectivity then go to access points, make a new one and name it Globe inet..then on the APN put this "http.globe.com.ph" without the "
2. then after that, go to internet profiles, make a new profile and name it globe inet.. name it Globe inet. then choose to use a proxy.. then enter this proxy address "203.177.91.131".. and then it the proxy server port, put "80".. then on the access point choose Globe inet..
3. now you need to make another internet profile.. so make a new one. name it "proxy".. then choose to use proxy, and then enter this proxy "195.189.142.132" then on the proxy server port put "80"..then on the access point put Globe inet..
4. ok now your done configuring your globe inet settings,. next step is to go to games and apps, then choose settings, then choose profiles, and add profile.. name the profile "proxy". then on the internet profile choose "proxy" then save it and activate it..
Feb 14, 2012 | LG Cell Phones
In my laptop windows-XP was installed. then i installed windows-7. then i installed linux Red Hat. die to some problem of internet connectivity, i had to replace redhat by fedora. after successful...
NTLDR means ............New Technology Loader ...........
this is one of the most crucial part of the Windows OS, this specific component looks for the loader of NT(Windows OS) which loads the required OS files of WinXP(earlier it was called WinNT)...the naming legacy is still being followed though the OS has changed from Win95, 98, NT, 2000, XP, Vista, Win7....
The only way u can get back this is by re-formating the drive using the WinXP disk....more info ...click the link
http://en.wikipedia.org/wiki/NTLDR
Sep 26, 2010 | Computers & Internet
Not able to access internet using samsung corby s-3653 as modem connection to pc
have you tried configuring your internet access through your samsung pc studio? if not, open your pc studio, connect your phone and create an internet access through internet connector and try to connect.
one way to check if you can connect to inet by using your phone as a modem, is, surfing the web first using your samsung corby's web browser.
if you can't connect or surf the web by phone browser, it means you still haven't configure your browser profiles to your network provider. ask the right configuration from your network and configure the browser profile first.
good luck..
Feb 26, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Configure Huawei E220 for Redhat 9
well depends on what u want to do, if u want to wipe out your old os and install redhat on the hdd, or you can dual boot, or you can use vmware to create a virtual machine. heres a website i thought would be useful, http://www.redhat.com/docs/manuals/linux/RHL-9-Manual/install-guide/index.html
Apr 24, 2009 | Acer Aspire One PC Notebook
Trying to setup 4500s i had fixed
Use the Wireless setup in Control Panel to configure your wireless connection. Setup your wireless configuration with the disc you received with your Router/Modem. Call your Inet vendor for help.
Apr 12, 2009 | Dell Dimension 4500 PC Desktop
Redhat es5
This model was found not to be 64bit but 32bit.
May 18, 2008 | HP Compaq ProLiant DL380 G4 Server
Computers & Internet Logo
115 people viewed this question
Top Red Hat Computers & Internet Experts
Joseph Wright
JonSnell Electronic
JonSnell Electronic
Stephen Miller
Are you a Red Hat Computer and Internet Expert? Answer questions, earn points and help others
