Question about Kenwood Food Processors
The problem is that the clutchdog, which is normally engaged by the peg on the liquidiser cover, is worn. Remove the top casing of the machine by removing the 3 screws and all of the outlet covers. Then unscrew the top of the gear box and prise open carefully with a screwdriver to expose the gears. The clutch dog can be unscrewed. Remove the spring that is on the outside of the gearbox and replace it on the inside of the gearbox so that it pulls the clutch dog down permanently. This then needs to be screwed back once the top of the gearbox has been screwed back together. Sounds complicated but it will be obvious when you try it. The machine will then turn the main attachment hub but will remain engaged as for later model machines. Hope this helps. John UK
Posted on Feb 11, 2011
Jul 31, 2014 | Kenwood KM336 Chef Food Processor
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
Jul 12, 2011 | Kenwood Food Processors
Mar 09, 2011 | Kenwood Food Processors
Jan 29, 2011 | Kenwood Food Processors
Jul 13, 2010 | Kenwood Food Processors
Feb 04, 2010 | Food Processors
Jan 31, 2010 | Kenmore KFP-70 Food Processor
Mar 13, 2009 | Food Processors
494 people viewed this question
