Question about Acer Extensa 5420-5687 Notebook
I lost my ethernet connection. It doesn't show up under the device manager. How do i get it back?
Posted by rtrombley759 on
Catalin Turcu
  • Acer Master
  • 4,924 Answers
First try to see if it appears on the My Network places...when you get there click on the view network connections..if the local area connection do not appear ..you have to try in the device manager to right click on the computer and choose to scan for hardware changes..this should bring the network adapter in sight ..if it is in yellow just reinstall the driver for it ..from the disk or the acer support site ..
or ..just go here and reinstall the driver for the Lan card directly ..
http://support.acer-euro.com/drivers/notebook/ex_5410.html
Posted on Jun 16, 2010
Hi............ i am using emachine E-725 windows vista laptop home premium 32-bit,2 gb ram,HDD-250. when i tried to access internet via wifi it shows like this "network adaptor not installed and...
Hi Good Day,
1) Try this simple steps:
click on the windows logo (START BUTTON) then right click on computer then left click on properties or system properties then click on device manager then under network adopter look for wireless LAN make sure it doesn't have an X mark if so the driver for your wireless card is not installed.
if your computer still under warranty then you bring it back to the store where you purchase it have them replace it with a working computer.
2) try connecting your computer via ETHERNET cable and if your able to connect to the internet that way it mean that there's a hardware / software problem with your wireless adopter installed in your computer.
Apr 08, 2011 | Computers & Internet
My acer 4310 connects fast to wi-fi pero pag internet cable na as in ung dsl hindi gumagana
When you plugged in the ethernet cable, does it show on your windows tray (lower right corner of the screen) that the LAN is connected? It should show you "Connected" if you hover your mouse on the LAN icon.
Try also to plug in the ethernet cable to a different port on the router, and that the port number on the router is showing a solid green led light.
If all has been observed and still you cannot connect, look if the network adapter for your lan is working. RIGHT click your My Computer or "Computer" and select Manage. The Computer Management window will open. Click on the Device Manager on the left to show the list of devices on the right. Look for Network Adapters and click the + sign. See if your LAN adapter is not showing any yellow exclamation point. Also, right click on it and select Properties. You should see the device is working properly under status.
Please let me know how this goes. Thank you for using FixYa.
Jan 22, 2011 | Acer Aspire 4315 Notebook
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
How to turn ethernet controller back on ?
go into the bios (F2 on powerup) and under Ethernet Adapter, Make sure it says enebled.
Oct 07, 2009 | Dell Inspiron 6400 Notebook
No desktop connection
Remove & reinstall your Ethernet adapter.
(right click) MY COMPUTER, Manage, DEVICES (Device Manager). All devices should show up by category.
under Ethernet/Networking you will see a Yellow Caution or a red X. Either way, click once on that line, and press DELETE key. Remove the device.
Close out, RESTART COMPUTER
This should trigger the system to re-install the Ethernet Networking Device. If you leave the Ether Cable plugged in, then you should automatically recognize/discover the network (nternet, etc).
If this does not work, then you should probably look your system up (support.dell.com, support.hp.com, etc) and identify the network device. You SHOULD be able to download the drivers write them onto a CD and transfer to Desktop #2.
If you have further issues, please contact me at 906-495-1707 or via YIM [email protected] or through this website.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Ethernet controller
If the device is functional but not listed under "Network Adapters" in the device manager, it may be listed under "Other devices" as an "unknown device" or ethernet adaper. I would suggest using another computer to go to support.hp.com. There type in the model of your laptop and "drivers" for a keyword. It should then take you to a support area where you can download the drivers for your network card, IF it is functional.
Sep 21, 2008 | Compaq Armada 3500 Notebook
IBM ThinkPad i Series 1200
Try this driver. I've used it on a few I-series Thinkpads that I've had come through my shop. After the download, uninstall the ethernet drive from the device manager, then reboot. The machine will find the ethernet port and reinstall the drive automatically. If this one doesn't work for you, let me know, an d we'll try a different one.
Aug 17, 2008 | IBM ThinkPad i1200 1161 Notebook
Westell Versalink, model 327W
if you are using the USB port of the modem, you should be able to see your modem while you are online, but if you are connect through ETHeRNET, you wont be able to see the modem on your device manager.
here is a USB port
and here is an ethernet port
Aug 12, 2008 | Westell Wirespeed VersaLink...
Acer Extensa 5420-5687 Notebook Logo
216 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
