I dont find stored songs when i them for assigning ring tone to a particular number and assigning songs to alarms. I only find default songs stored on phone memory.
Inorder to assign a ringer id on Moto phones, Plz goto to contact of a particular person u want to assign thru phone book, U will find a an option RInger ID.
Note: This option shows up only if the contacts are saved in phone memory.
You can always refer ur phone manual. (if u dont have a manual then, you can download the eManual for phone)
Creating Phonebook Entries
To store names and numbers in your Phonebook, please follow these steps:
When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key).
To create a new phonebook entry, press the NEW soft key. Edit Name appears.
Enter the name for this entry (Edit Name).
Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished.
Enter the number for this entry (Edit Number 1).
Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished.
EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished.
Assign a personal ring tone for this entry (Personal Ring).
You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting.
Assign this entry to a Speed Dial number (Speed Dial).
Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key.
You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display.
Note: When the shared memory is full, the oldest Caller ID message is overwritten.
u need to go contacat list then
contact seting and then u get a option of image used as wel as ringtone used or assin tone then u can set specific tone for each number..
i) go in the option Phone Book---> Add a New Entry----> To Phone(Not in To Sim)----> you will get all option such as name, office no, personal no, caller picture, caller video..
you will get these option only when you store the number or new entry in the phone memory rather than sim memory
OR
ii) type the number you want store and click the option save and now save in the phone memory rather than the sim memory, you will all option such as name, office no, personal no, caller picture, caller video..
ring tone:
go to memory card or any other place where you ring tone files or song files are present try to highlight it(dont click it) and at the bottom you will 'option' click on it you will get a list of option in that you will have 'set at ring tone' clik on it and you'll be able to set your own ring tone....
download the free app ringdroid in the app market.connect g1 to computer and mount .drag music into music folder.then open rigdroid.the music you dragged into folder should be here.cut the waveform however you want then save. now you can go to settings and under sound and display you can assign your newly made ring tone to your default tone.
A lot depends on your model of phone.
My phone I can assign a specific ring tone to each phone #. So annoying numbers I have assigned them as a Mute ring tone.
When you edit a phone number, it should give you options as to blocking, assigning a ring tone, saving etc.
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
