Water is leaking out the top it appers that the water is coming from the fill valve above the back rim because when I touch that part water spils out even when machine isn't running
Hi just read your posting.When you say the water is leaking out of the top ,does that mean it is leaking on the floor or leaking into the bowl even when the machine is off.If it is leaking into the bowl then it is a faulty water valve.Turn off the cold tap and leave for an hour and see if the water stops and if it does stop then the problem is the cold valve.If it doesn"t stop the leak turn the hot off and leave for an hour and see if that stops the leak.By memory I think your water valves are a double unit and to change one you must change both.Please reply with additional information about where the water is leaking to and I can help you rectify this fault,
Hi just read your posting.Now just to clarify a couple of points.In your first posting you mentioned the water was leaking from the back rim even when the machine is turned off,Is this still the case?In the last posting you mentioned that the water is only leaking when it is on rinse or spin,Is that correct?Now just a question, where is your water draining to? Is it into the laundry sink or somewhere else.Did you try turning the taps off when the machine is not being used to see if that stopped the water leaking from the back rim near the water valves? Sorry to ask you these questions but to repair this fault I need the answers to the questions in this posting and that will make it easier to track this fault for you.
Hi just read your posting.Now this sounds like the water is not draining quick enough,so it goes to spin before it is empty.Therefore the water vortexes and goes over the top of the bowl.Now, where is your machine draining to? Is it into the laundry sink or somewhere else? Please look underneath the machine for me to see if you have the pump with the fan attached.On this model there are two types of pumps ,one with a fan which should be colored red or black or the style without a fan. Please reply with additional information on the questions and I can help you rectify this fault.
Hi just read your posting Sorry to be a pain, but Could you give me some more information on the questions in my second posting.The answers I need are about where the machine is draining to and which pump you have on your machine.Please reply and I am sure I can help you repair this fault quickly.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME
Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. . Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.com Buy Fill Hoses Here.
LEAKS DURING FILL CYCLE
Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.com
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.com .
LEAKS DURING WASH
Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.com
LEAKS DURING PUMP OUT
Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
The water appears to be coming out of the lid in front in the rinse and spin cycle
I described wrong the 1st time. The water is spitting out the front and over the drum in the last spin cycle. Doesn't leak when off.
