Question about Samsung CLP-315W Laser Color Printer
My samsung printer clp 315 has a paper jam with about 1/3 of the paper out the exit everytime
Posted by jonesacca on
Roy Goering
From You Tube:
http://www.youtube.com/watch?v=5fJHykzkfww
DIY video tutorial on how to repair the Samsung CLP-315, CLP-301 laser printer "paper jam" problem, where the paper stops printing about halfway through for no apparent reason. My printer worked great otherwise, but was out of warranty. It would have been less expensive to get a new printer.
The problem is a very cheap sensor.
This repair takes 15 minutes and is inexpensive. Read the comments below.
I got the part from SamsungParts.com. Search for part #0604-001393
Posted on Jun 08, 2012
Anonymous
  • 526 Answers
It sounds like the sensor on the fuser is not working properly, or a possible broken gear on the fuser.
I dont believe the sensor on the fuser can be replaced, exchanging the whole fuser would be the fastest repair.
Posted on Jun 16, 2010
  • bynarside Dec 30, 2010
    Try opening the front door then shutting it, if the paper powers out with half a print this indicates the exit sensor, you can also try lifting the cover over the outfeed itself the printer should not run paper through at all, if it does again this idicates the exit sensor.
Samsung clp 310 printer regularly jams
if your printing is halfway to the exit. it is most likely the exit sensor is mulfunction.
get the exit sensor replace.
May 14, 2010 | Samsung CLP 315 Laser Printer
My Samsung CLP-315 Laser Printer will print about a half page and then jam...everytime!
does the jam came out to the exit and stuck there or it jam in the printer or before the pickup?
if it got jam at the exit. the exit sensor is faulty it got to replace.
if it got jam in the printer. the transfer belt or fuser is faulty. both got to replace
if it got jam before pickup. pickup roller got to replace.
May 09, 2010 | Samsung CLP 315 Laser Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
Printer stops hafway the print, giving paper jam. once paper is removed it still gives 'paper jam' , once turned off ad on is disappers but next print is still jammed halfway
Yes, bad exit sensor. Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Apr 11, 2010 | Samsung CLP 315 Laser Printer
Paper lifts on clp 315 and then stops halfway and flashes paper jam light but nothing seems to be jammed paper ok any ideas
This is the problem in the exit sensor of the printer. Please approach authorised service center they will change for you.
Oct 20, 2009 | Samsung CLP 315 Laser Printer
Paper Jam began for no apparent cause. clear the
This defect is due to exit sensor problem. You may approach Samsung Authorised service center. They will repair for you.
Jul 30, 2009 | Samsung CLP 315 Laser Printer
Samsung ClP315 jams everytime ,
This problem is due to exit sensor in the exit area. To get it serviced kINDLY APPROACH AUTHORISED SERVICE CENTER.
Jul 05, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-315
paper exit sensor faulty,common problem with this printers.
Jun 08, 2009 | Samsung CLP 300 Laser Printer
SAMSUNG CLP 315 paper jam
the printer may be detecting dust or something on the sensor, and detecting it as a jam
try to get the sensors cleaned, tell us how you go
May 19, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-315W Laser Color Printer Logo
1,332 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
